A4 2.0 TDI 170 - 160,000 miles - Too much?
Malorrr Jul 13, 2018
  1. Malorrr
    Malorrr New Member
    Hi All,
    I'm going this evening to look at a 07 A4 Avant S Line 170bhp with 160,000 miles. The car is specced very well and from the pictures it appears to be in great condition. The car is priced very well and it's appealing to me as it's exactly what I'm looking for in terms of spec.
    I've started doing about 50,000 miles a year so I will basically be running this car into the ground, I was thinking firstly of getting a car with closer to 100k but either way, I will be sucking the value out of the car. My questions would be firstly am I mad?
    Secondly what should I look out for maintenance wise that has been done on the car, obviously timing + water pump and a clutch at some point but should the turbo have been replaced at this mileage too?
    The car is a good 2k cheaper than any other 100k example, so my thinking is that with the mileage I'm doing there really isn't a point in spending more money as I will be knocking out any value straight away, and with the left over cash I should be OK for any issues that come up.
    This is a BRD engine, which I believe is not as bad as the BRB engines for oil pump issues but is it something that should be looked at with a car at this mileage?
  2. Avatar
    Google AdSense Advertisement
  3. daytonamart
    daytonamart Moderator Staff Member Moderator
    325
    438
    With proper maintenance this engine will do 300k no problem.
  4. b6ben
    b6ben Member
    39
    12
    I had a 2.0tdi BRD engine my last car and I did the oil pump mod at about 120k, and let’s just say I’m glad I did it as the shaft was well worn.
    It’s kind of pot luck when/if they even fail, sorry if this isn’t what you wanted to hear.
    I wouldn’t let that put you off though, just get it sorted with the money you have saved and it will run forever.
  5. Retroman
    Retroman Audi A3 2010 Sportback 2.0 TDI 170 (CBBB engine)
    1,046
    331
    Apart from obvious wear & tear issues the engine/turbo should be fine as long as it's had good, regular engine oil maintenance. I'm wary of any car where this maintenance is patchy or partially missing.
    Sibmets likes this.
  6. Nikymann92
    Nikymann92 New Member
    13
    Aryt guys I've recently bought an A4 2.0 tdi sline 170bhp 06 plate saloon with a similar 170 on the clock got it cheap and it does need abit of love, is there any recommendations on anything I can do to get it to its full potential or anything that I should be wary about going forward?
    Melorr I am interested if you got the one you went to see and how it's turned out with the mileage you've been doing haha
    daytonamart likes this.
