had this problem for a few weeks and it's got so bad I can't drive the car. Started with just a judder where by the revs drop then come back again, now it also just cuts the engine completely and I have to leave it for a few minutes before it will start. Can Happen at any time, ie under load or not, straight road or on a corner, doesn't seem to matter. Have changed the plugs and run Vag com a few times but no errors show up. Was thinking either throttle body or maybe maf or coilpacks? I have also tried the throttle body reset after disconnecting the battery but it's just the same and is now getting more frequent. There is sometimes a low pitch electrical drone noise that cones from the throttle body itself which I noticed when the ignition is on but the engine isn't started, doesn't make this noise all the time though, is it normal? Or indicative of a problem? Any ideas or advice would be great. Cheers
