A3 Sat Nav Update?
Datastorm
Hi All,
Been away for a little while, with a Mk7 Golf taking up my time, but I'm getting the itch badly for another A3.
Quick question, since I've been gone the sat nav units appear to of changed in the new models (my previous car was an '09 with an RNS-E unit). I see the new units pop-up through the dash, very smart.
I've had a quick look around on the Internet, but I couldn't see any update discs/cards for them available through the normal channels. Are they user updatable, or is this a main stealer only activity?
Any advice is greatly received.
Datastorm
I didn't realise there were 2 models to choose from. Assume thats one of the differences between the HDD & SD versions then?
RichardT
All in the brochure.......
mjcourtney
Agreed! Have a good read through the brochure and then pop back here afterwards to ask any follow up questions. The biggest change to the A3 between the 8P and the 8V was the in car tech, particularly the sat nav / tech pack - so its worth reading up on the options first.
Note: SD Nav can only be activated by main dealers, and map updates are around £150 each. Dodgy / 2nd hand SD map cards found online won't work and can't be activated (or not yet at least).
Tech pack comes with higher res screen, sat nav with 3D mapping and touch pad input, plus a number of free map updates for a number of years. But it does cost £1500....
Datastorm
Perfect, exactly what I was after, thank you.
