A3 quattro running "326bhp" help
JsAudi Nov 21, 2017
  1. JsAudi
    JsAudi Member
    57
    Hey guys as you can tell from my post count I'm new. I have been lurking in the shadows for a while trying to research issues I have been having with my car.
    Now firstly my car is a 2000 a3 quattro with a bam engine fitted k04 turbo, 3in exhaust, 550cc injectors, fmic, forge piping and mapped. I have a dyno print out of what the car was producing and it clocked 326bhp and 277lbs ft. But I'm not here to dispute numbers as from what I have read my print out could be quite generous.
    Anyway back to the point of my post. The car has a 5 speed manual with supposed updated clutch but recently I'm sure it's starting to slip when hitting boost but only in 3rd and 4th. What are my options for putting a new clutch in? I am going to ditch the DMF. can anyone recommend anything given the supposed power out of the car?
    Now here is where it gets a bit tricky. I don' have access to vagcom or vcds at the moment but if I keep the car it will be something I will invest in. I am fairly new to audi turbos. Have always been a honda man and still am. This is mearly a daily driver for me.
    Now when I bought the car there was no diverter valve fitted to it. He also said that he got something added to the map too make it pop and bang a lot when you lift off above 3000 rpm. Now i personally think now he's talking garbage.
    When trying to hold the car above 3000rpm it constantly lurches kind of like tapping the accelerator pedal fast in first making the car undrivable. Its fine when you accelaerate through or lift of completely. Is what he said true or after noticing he removed some parts from the engine from the original advert namely ramair filter red coil packs could it be that he has removed the bigger injectors and fitted the stock 1s back in? Is there anyway too check what injectors are fitted?
    Sorry for the long winded first post I hope it makes sense. Advice and pointers welcome.
    I will try and get some pics of the engine bay so you can have a look. I have since fitted a dv to the car because the guy never had 1 fitted I asked why and he said he had nothing but issues with it fitted.
    Jamie
  2. Avatar
    Google AdSense Advertisement
  3. Rainbird
    Rainbird Well-Known Member
    445
    268
    A fair whack of potential confusion here. If you're able to post up the original ad and a handful of photos it should help clear things up nicely.
  4. Stuart B
    Stuart B Well-Known Member
    3,448
    742
    When I switched on my pops and bangs (total **** and ruins stuff) it was done by retarding the timing quite heavily at low loads this caused the car to have horrible engine breaking, and you couldn't accelerate slowly. but your lurching sounds more like a misfire. maybe the problems you are experiencing are the ones he was talking about hence no DV.
  5. JsAudi
    JsAudi Member
    57
    So it is a thing that can be added too the map then. Well at least I know thats true. It isn't a misfire that's causing it. But yeah you can't hold the car at 3000 rpm because it makes it undrivable.
    The issues were there before having the dv fitted.
    I will try see if I can find the original ad. And get pics up.
    What's the best direction to go regarding the clutch situation?
  6. Rainbird
    445
    268
    That depends on what's actually going on with the car (if it's a stock k04-02x then 326bhp is unlikely, however it could be a hybrid of some form etc). Actual power/torque level, as well as your intentions for the car, will have an impact on the best recommendations.
    A look at the likes of Sachs, Helix (Sorry Bill!), CG Motorsport and the like will give you a good idea of what's out there and prove a start point, as well as some forum trawling (plenty of info on running a G60/VR6 setup etc)
  7. Stuart B
    3,448
    742
    I cant help you with the clutch - I think mines hanging on by the skin of its teeth.
    does it not pop and gargle on a run down say from accelerating in second over 30 then backing off the throttle. mine was based on simply overfuelling on load then retard massively on low load, so you wouldn't get it when driving around slowly - but coasting on a motorway was a nightmare you either needed to accelerate or brake - but I think my exhaust is blowing a bit more now.
    here Ian did it properly for his S3 with flames - pretty sure it was a few days before an engine rebuild started.
    http://www.audi-sport.net/xf/threads/not-another-nogaro.278975/page-3
  8. antwan64og
    antwan64og Well-Known Member
    1,040
    273
    Do you have an 02J or 02M gearbox?
    02m is 240mm, Sach SRE is the go to clutch under 400 ft lbs, choice of organic clutch or paddle.
    02J is 228mm, you can use an ABF or G60 single mass flywheel with a VR6 clutch.
    Stock VR6 clutch is rated to 320 ft lbs or so but you can get an uprated one for cheap.
    02j gearbox is know for being relatively weak, and the upgrade is the 02m
  9. JsAudi
    JsAudi Member
    57
    Tbh I'm quite happy with the power output. I'm generally quite sceptical with dyno figures. So as for increasing power that won't be happening. It's daily driver for me I have my other toy for fun. I'm guessing an oem won't be up too the job?
  10. JsAudi
    JsAudi Member
    57
    Yeah it does it on the over run and down rev. So dropping off power above 3000 rpm. Sounds nice but jus can't handle the lack of drivability trying to keep a constant speed above 3000 rpm.
  11. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    2,757
    742
    It’s very generous if it’s a standard ko4 but if it’s a hybrid I’d expect more torque
    Stuart B likes this.
  12. Avatar
  13. JsAudi
    JsAudi Member
    57
    I have no idea of the gearbox code I'm afraid. All I can tell you is it's a 5 speed manual quattro gearbox.
  14. Rainbird
    445
    268
    02M is 6 speed.
  15. JsAudi
    JsAudi Member
    57
    Cool thanks
  16. ben4866
    ben4866 Member
    65
    I thought they did an early 02m 5 speed?
  17. <tuffty/>
    23,455
    5,023
    They did 02M in 5 speed as well as 6 speed for the quattro's... this will be an 02M 5 speed box...
  18. Rainbird
    445
    268
    Oh really? I was blissfully unaware of that (evidently!). Every day's a school day :relaxed:
  19. JsAudi
    JsAudi Member
    57
    So I would be right on saying it'
    Still the 228mm clutch disc?
  20. <tuffty/>
    23,455
    5,023
    Pretty sure its a 240mm
  21. <tuffty/>
    23,455
    5,023
  22. Stuart B
    3,448
    742
    torque limited under the imaginary 280 breaking point?
  23. superkarl
    superkarl MAN OF STEEL
    9,957
    2,645
    Stock clutch should handle 277lbs comfortably IF not driven like a bell. Daily driver so, I’d say it’s suitable
  24. SamHendry
    SamHendry Active Member
    827
    165
    43
    I'm on 306lbft with stock clutch, over 3k now, multiple launches, an hour on track, still holding up,
  25. JsAudi
    JsAudi Member
    57
  26. <tuffty/>
    23,455
    5,023
    You can use a SMF on an 02m... you just got to get the right one... it will make the gearbox chatter like mad on idle though....
    I still use a DMF on mine and I am running a bit more power than you... it works, its quiet and you don't need to go to the gym to be able to use it in traffic
  27. JsAudi
    JsAudi Member
    57
    I would rather fit a lighter flywheel anyway. Plus if you tried the clutch on my crx anything feels light. A good drive in it and you come back with a left calf like arnies lol.
    So complete noob question here what would be the right 1?
  28. <tuffty/>
    23,455
    5,023
    No idea :)
    @Prawn runs an SMF in his track car so may be able to point you in the right direction... there are a few 'iffy' ones available from certain clutch manufacturers that we cannot mention...
    TTV make SMF's, CG Motorsport seem to have a decent rep too...
    JUst be aware that the A3/S3 quattro is not a light car... go too light on the SMF and it will be an a$$ to drive... welly fitted an alloy one from fidanza to his S3 and was forever stalling pulling off (fnarr..)
    scotty_24 likes this.
  29. JsAudi
    JsAudi Member
    57
    Ok cool. So it's not something I will get from a motor factors then?
  30. <tuffty/>
    23,455
    5,023
    not really... std part is a DMF... there is no 'factory' SMF for an o2m gearbox setup
  31. JsAudi
    JsAudi Member
    57
    Cool I will check cg motorsport. Is there anyway to turn off that ridiculous pop and bang thing that's on my map? Or is it going to be a case of getting the car remapped?
  32. <tuffty/>
    23,455
    5,023
    remap dude...
  33. Avatar
  34. JsAudi
    JsAudi Member
    57
    That what I thought.
    Cheers.
  35. JsAudi
    JsAudi Member
    57
    I have another question regarding the engine. Why would someone disconnect the cam chain tensioner unit on the end of the head and jam a resistor in it? I have pulled the resistor out and plugged it back in and it seems to not make any difference? Eml light doesn't come on when it' plugged back in. I'm guessing it has something to do with the vvt system?
  36. <tuffty/>
    23,455
    5,023
    Your car shouldn't come with VVT IIRC... 2001 and up had VVT...
    Whats the engine code? you can find it here...
  37. JsAudi
    JsAudi Member
    57
    It was originally an auj I think. It has the BAM engine in it now.
  38. <tuffty/>
    23,455
    5,023
    Explains why its got VVT and its not connected... wonder if they did a wideband conversion too...
    Gonna be one of those mongrel cars you need to see to be able to work out if its an issue...
    What did they jam the resistor in? if its the original wiring loom then it won't have a connector for the VVT... they could have done an N249/N112 bypass and got rid of the solenoids... doesn't always work and can cause issues with fuelling... depends what other work (or bodges) they have done I guess...
  39. JsAudi
    JsAudi Member
    57
    I can only assume that they used the BAM engine loom. I found the plug wrapped round the dipstick with the resistor in it. The joys of buying other people's work. Lol. It seems to run fine with the resistor in and also when you actually plug the sensor in. I think what I will do later is get some photos uploaded of the engine bay after work as it may give a better idea as too what's been done.
  40. JsAudi
    JsAudi Member
    57
    Would getting it on vagcom shed any light on it?
  41. <tuffty/>
    23,455
    5,023
    should elude to what ECU number etc is in use...
    Given what it is (or isn't) yo might be better off booking it in with Bill or a n other specialist to give it a once over... if its been 'played' with then its not going to be easy to diagnose issues without knowing whats been changed from standard
    Have seen loads in my time and engine swaps are generally a real pain as the subtle differences between them tend not to get sorted out correctly and while they run they don't run well..
  42. JsAudi
    JsAudi Member
    57
    Yeah that was my intention after Christmas. Being based in the north of Scotland has it's disadvantages. There is a place in kirkcaldy that deals with tuning audis. Thankfully they do things properly as oppoed to generic flashes. But judging by the figures already on the dyno sheet I would say it was running alright at the time. Although I think it could be improved a bit. There's a few things that have jus rung alarm bells with it now after doing some digging and having a proper look over the car. That sensor being 1, no recirc valve being fitted and that ****** popping and banging thing he put on the map. Now possibly a new clutch in the future and it did develop a misfire but I got a hold of new second hand coil packs and that seems to have sorted that.
  43. Stuart B
    3,448
    742
    what fuel are you using ? momentum or shell v power?
