staz1000 said:
Nope that is incorrect. There is only circuitry for one fog and one reverse light.
That is incorrect for the fogs anyway I have both coded to work on my car.
heres the instuctions to Enable Rear Fog Lights:
* Click on '09-Central Elect'
* When you go into this module, it will scan for fault codes and go straight to a fault code screen. It should say 'No Fault Codes Found'. Click the 'Done, go back' button to get to the main screen for this module.
* Click on 'Long Coding - 07'
* You may get a pop-up warning, click 'yes' for long coding
* WRITE DOWN your original long code before doing anything else at all.
* Click on 'Long Coding Helper'
* In the Long Coding Helper, set:
o Byte 03 bit 01 to '0' for both rear fogs, or '1' for 1 rear fog
o Byte 04 bit 04 to '1'
o Byte 04 bit 06 to '0'
* Click 'Transfer Coding'
* Quit out of the Long Coding Helper
* See that the new Long Code differs from the original one
* Click 'Do it!'
* Verify that the new Long Code is stored.
* Click 'Done, go back'
* Click 'Close controller, Go Back'
You can find more info on the long coding sheet here
http://oooo-a3.blogspot.com/2006/02/a3-can-system-long-coding-worksheet.html, i bet the instuctions for both reversing lights are there too.
