A3 8P ESP fault? help
phil miller
Devon
Hi all ive got an A3 TDI 2lt on an 03 (it is an 8P)
i have the following fault codes, ESP light is on, ive tried to do basic settings but it wont let me enter 40168 or 15082, it says NOT SUPPORTED BY CONTROL MODULE
Ive fitted a known good ABS pump and module and get the same issues
Can anyone help me please?
full scan is here, yes there are other codes but its just the ABS im worried about
Thursday,15,January,2015,11:27:05:22373
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WAUZZZ8PX4A035192 License Plate: MOORVIEW A3
Mileage: 218600km-135831mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8PX4A035192 Mileage: 218600km-135831miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0C5FNI05T
Coding: 0000072
Shop #: WSC 06435 000 00000
VCID: 275BA70796BA71190E1-8072
1 Fault Found:
16785 - EGR System
P0401 - 000 - Insufficient Flow
Freeze Frame:
RPM: 1386 /min
Torque: 48.0 Nm
Speed: 0.0 km/h
Load: 9.4 %
Duty Cycle: 14.7 %
Bin. Bits: 11000100
Mass Air / Rev.: 320.0 mg/str
Mass Air / Rev.: 550.0 mg/str
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 D
Component: ESP FRONT MK60 0102
Coding: 0055942
VCID: 3363435752620DB9A29-8066
3 Faults Found:
00810 - Sensor 1/2 for Brake Pressure
005 - No or Incorrect Basic Setting / Adaptation
00778 - Steering Angle Sensor (G85)
01423 - Lateral Acceleration Sensor (G200)
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 B HW: 8P0 820 043 B
Component: KlimavollautomatH11 0120
Shop #: WSC 00000 000 00000
VCID: 2B535B378A525579EA9-807E
2 Faults Found:
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 70
Mileage: 218609 km
Time Indication: 0
Date: 2015.01.15
Time: 12:24:24
Freeze Frame:
ON
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 60
Reset counter: 69
Mileage: 215402 km
Time Indication: 0
Date: 2014.10.10
Time: 15:51:25
Freeze Frame:
Temperature: 9.0°C
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H27 0401
Revision: 00000000 Serial number: 00000006626542
Coding: 01884F00A2141000000000000000000000
VCID: 3B736B777A32C5F97A9-806E
Subsystem 1 - Part No: 8P2 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
1 Fault Found:
01506 - Bulb for Rear Fog; Right (L47)
012 - Electrical Fault in Circuit
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
Component: Airbag 8.4ED H01 0130
Coding: 0011602
VCID: 45870D8F0CF683091CD-8010
No fault code found.
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 007 0030
Coding: 0000012
VCID: 30694C5BA37436A1DFB-8065
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 980 D HW: 8P0 920 980 D
Component: KOMBIINSTR. VDO H25 0070
Revision: D04 Serial number: 2245CD04001216
Coding: 0004403
Shop #: WSC 00623 210 91761
VCID: 3879747B4B04EEE197B-806D
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 B HW: 1K0 907 951
Component: Gateway H08 0070
Revision: 08 Serial number: 170010351631F3
Coding: 3D0F0B42070101
VCID: 2645AA0391B06811357-8073
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D04 Serial number: AUX7Z0C5FNI05T
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H09 0010
Coding: 0000048
VCID: 397F717F700EF7E9685-806C
2 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
00105 - Signal Central Locking SAVE/LOCK Drivers Side
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 36657A4341101891857-8063
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433
Component: KSG H02 0030
Coding: 008800186D288505485AC63000
VCID: 79FFB17F308E37E9285-802C
Subsystem 1 - Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Subsystem 2 - Part No: 1K0 907 719
Component: Neigungssensor 002 0002
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H01 0010
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH23 0100
Revision: 00001 Serial number: 10000001027356
VCID: 70E98C5B63F476A19FB-8025
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000048
VCID: 3A7D6E737508FCF161F-806F
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 HW: 8P0 035 195
Component: symphony II EU H53 0280
Revision: 17S Serial number: AUZ5Z4C5289838
Coding: 0001001
VCID: 6FEB8F277ECA6959861-803A
1 Fault Found:
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 7
Reset counter: 69
Mileage: 217861 km
Time Indication: 0
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 A HW: 1K0 963 235 A
Component: PTC-Element 0303
Revision: 00400000 Serial number:
VCID: 295FA13F80AE4769185-807C
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 01:33)--------------------------
Address 03: DTCs cleared
Read this!
Scroll down to the Adaptions instructions on the above linked page and follow the steps EXACTLY as set out by Ross-Tech.
You need to log in between each one and I usually get the brake pressure and acceleration sensor out of the way first.
Reactions: phil miller
Read this!
Thanks mate, worked perfect
I've got the exactly the same problem sent my abs pump of to be tested said it was fine do you think it will cure my problem of I use that guide ?
Certainly could do. Are you getting the:
Error too?
Yes exactly the same g200 fault brake pressure sensor 1/2 and g85 steering angle sensor on the dash it comes up with a "A" with a circle arrow around it
2015 03 30 220403
I've also got these codes don't know what they are I've having a lot of problems with my alarm everytime I lock it it goes off and can't turn it off I've temporary fixed it by pulling out a fuse but since I've done that I've lost my rear parking sensors and my cruise control
2015 03 30 220659
The Steering Angle faults should be resolved using the basic settings from the link @Mr.Doc posted earlier.
With regards to the vehicle inclination sensor, this is used to detect if the vehicle is being jacked up and if it detects it, it sounds the alarm.. it sounds like it could be a faulty sensor which is sending wrong signals and is causing the alarm to go off, which is happening in your case.
I believe you have a few options here:
1) Replace faulty sensor (G384)
2) Remove inclination alarm functionality from VCDS (if possible?)
3) Every time you get out of the car, de-active the inclination sensor by pressing the incline alarm button on the inside of the drivers door. Bottom button in the below image:
Thanks for your reply tbh I'm not even bothered about having a alarm it's just in remove a fuse to stop it going off because it was draining my battery and i couldnt lock my car but I've lost my parking sensors and cruise control which is abit annoying but better than a dead battery every morning
Happy days thanks everyone no more traction control on my dash board ! Soo happy !!! Thanks especially to Mr. Doc for the guide !!
Help steering has gone really heavy now I have done that ?!?!
Hi thanks guys it's sorted now had to adjust the steering limit stop all sorted now a big thank you too all !
861
NHN
17
3K
921
