A3 3.2 Quattro 8P Bearing Carrier
Will1893
Hoping someone can help me out.
I need to get a second hand hub/bearing carrier for my 2005 3.2 a3 n/s front. But I can't seem to find any that have come from a 3.2 quattro, loads from other models and engine sizes.
Just wondering if anyone knows what models/engines use the same parts so I can look for them.
Thanks in advance.
Sent from my SM-G981B using Tapatalk
abmat
Well-Known Member
I think the MK4/5 golf R32 might.
aqibi2000
Read the part number it’s probably the same on the 2.0 TFSI/ TDI Quattro
abmat
Well-Known Member
Also there’s loads of them breaking on eBay.
Will1893
This:?
https://www.ebay.co.uk/itm/For-Audi...-/143019555736?_trksid=p2349624.m46890.l49292
Id also add enquire at your local dealer. Sometimes you’d be surprised at the prices(in a good way) and you’ll have piece of mind knowing it’s the correct part and will fit.
Its the part that the wheel bearing is attached to, that is also attached to the steering link.
After doing some research I think all audi A3 8P1 use the same part, I'm going to a breakers tomorrow so I'll find out then and report back.
abmat
Well-Known Member
Do you mean the hub carrier. The bottom of the shock also mounts into it?
