Rears are dead easy.
Fronts more involved .
Haynes etc say you can leave front wheel hub in-situ and just split the suspension leg to remove shocker etc but as per usual these manuals don’t take into consideration parts rusted together etc after many years use .
I had to remove the whole suspension leg as I renewed the front hub bearings at the same time .
If I had tried to split suspension leg in-situ I’d have failed as it was rusted together solidly.
One side of the car the front top bearing mount screws also had rusted solid , ended up having to grind out the securing screw with an angle grinder from below after chopping the shock absorber piston in half to allow access!
I was lucky to have the car in my garage and under cover , wouldn’t have wanted to have done the work out in the open!
It took me well over a day of solid working to do all the jobs and I’ve got quite a well-equipped garage .
