Just wondering if anyone could advise if the alloy inlet manifold from BKD engine 03G129713 fits on BMN engine to replace the current plastic one. I believe some BMN engines came with alloy inlet.
Bought this. http://www.ebay.co.uk/itm/171677022994
So here's hoping it fits. I'll keep you informed. If so there are a few more on eBay for a cheap replacement.
On researching BKD and BMN use the same inlet gasket http://www.darksidedevelopments.co.uk/products/2-0-16v-tdi-pd140-pd170-inlet-manifold-gasket.html so to remove flaps use BKD manifold.
Also found this which says fit BMN engine.
http://www.tornau-motoren.de/Saugro...da-VW-20-TDI-/-BMN-/-03G129713H-/-03G129711AR
Yeah think the 140 bhp alloy one fits but doesn't have swirl flaps so I understand. Lose a little bit of low down torque so will have to rev it a little more using the bhp instead of the torque. Extra use of fuel may only be negligible.....who knows?The BKD 140 manifold 03G 129 713 fits the BMN 170.
I've spoke to Darkside and they confirmed it fits straight on. My swirl flaps have failed and will be fitting the £25 140 ally manifold to my 170.
Hopefully Neil will confirm this.
Dave.
Hi WILKYA3 ANY LUCK FOR YOUR BKD MANIFOLD DOES IT FIT DIRECTLY TO YOUR BMN 170 ENGINE?
I'm interested to know how your engine management light didn't come on? The swirl flap actuator (as I understand) has a limit switch in on it & if it doesn't fully open & close it throws up an engine check fault do I'm told.Jay. I swapped my plastic one for an alloy one. I've got rid of the swirl flaps and no engine management light on. I got a golf one for 35 quid on eBay which I fitted to my Audi.
Jay I did replace it with another plastic one with the swirls flaps from German Auto Spares Ltd off the net. Genuine vw/Audi/seat/skoda boxed part. £503.14 I paid may 2014. It's supposed to be modified to stop the leak so even if you get one from a scrappy it's probably an old style one & will eventually leak, Wanted over £600 for the part from the dealers. Came in the box with the manifold gasket. You'll also need gaskets for the egr valve & intake flap. Approx another 3 small seals / gaskets @ about £14. You can reuse the bolts for the manifold if you put a small amount of stud lock on them when refitting the manifold.Bedders did you replace yours with another plastic one with the swirl flaps ?
Short sighted view from the manufacturer in my opinion! Reliability & low running costs are on most people shopping list these days. Replacement of the manifold must be a £1000 job at the dealer through their poor design or acceptance of a suppliers poor design.The reduction in cost of the manifold is for the manufacturer (VAG), not the customer. It's such an essential part of the engine VAG know they can charge whatever they feel like for it & the customer will just have to accept it or have a faulty engine function.
