marci4
A3 2.0FSI SPORT
- Joined
- Oct 4, 2016
- Messages
- 33
- Reaction score
- 7
Hi all,
Through a series of events I am now the owner of a 2004 A3 with 1.6 BGU under the bonnet. However I'm facing a bit of issues and don't really know where to look for the cause of them.. The biggest one is when I change into 2nd (no difference if it's an upshift from 1st or downshift) the engine loses the power. I can go full on the gas but the revs are somewhat stuck at about 2500-3000 and the car isn't accelerating. Once I press the clutch in and let go and then go on the gas pedal it goes back to normal and accelerates fine. It's also accelerating fine an all the other gears.
VCDS shows only one fault in the engine:
17947 - Clutch Pedal Switch (F36)
P1539 - 008 - Implausible Signal - Intermittent
I've read that this switch is used in Cruise Control to turn it off when you press the clutch, but my car doesn't even have that fitted so would that make a difference?
Anyone has any suggestions where to look for the source of issues?
