A3 1.6 2006 bgu
Sean farrell Sep 23, 2018
  1. Sean farrell
    Sean farrell New Member
    Ok I'm having this issue a while now,
    What I've done so far to try and fix it but no joy
    Coil and leads
    New spark plugs
    New map sensor
    New clutch pedal sensor
    Cleaned egr valve
    Cleaned tb
    The issue is when I accelerate sometimes the response takes a few seconds.
    The idle is poor sometimes
    When it's really cold out and when I start it early in the morning the idle is crazy for about 20 seconds.
    Any suggestions please? ??
    Sent from my SM-G900F using Tapatalk
  2. Avatar
    Google AdSense Advertisement
  3. maxpayne
    maxpayne Active Member
    924
    185
    43
    Have you tried scanning fault codes using VCDS? What does it say?
  4. Sean farrell
    No faults are showing
  5. Sean farrell
    When I tested it I showed two things
    Running too lean
    Clutch pedal switch
    I reset them and no codes now
    When I accelerate and I hit this flat spot if I hit the clutch it goes away
  6. Sean farrell
    This is the plug I just took out ?[​IMG]
  7. Sean farrell
    Anyone ?
