- Joined
- Nov 4, 2006
- Messages
- 2,631
- Reaction score
- 82
Anyone know how to code out reverse light error?want to fit led ones,i have 5 different version of led reverse lights and all throw errors........rather code em so i get no errors.
Friday,05,July,2019,18:01:53:07086
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 19.6.0.6 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8X5CB039627 License Plate: A1 61 PLATE TDI
Mileage: 219220km-136216mi Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 5F
VIN: WAUZZZ8X5CB039627 Mileage: 219220km-136216miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 KQ HW: 03L 906 023 KP
Component: R4 1.6l TDI H63 9978
Revision: --H63--- Serial number:
Coding: 00114016030501080000
Shop #: WSC 00046 790 00000
ASAM Dataset: EV_ECM16TDI02103L906023KQ 003015
ROD: EV_ECM16TDI02103L906023KG.rod
VCID: 7F0710B2E6E6D2B7EC-802A
2 Faults Found:
10116 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 4
Mileage: 218826 km
Date: 2019.05.14
Time: 17:31:09
Engine speed: 1911.75 /min
Normed load value: 0.0 %
Vehicle speed: 102 km/h
Coolant temperature: 95 °C
Intake air temperature: 36 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.456 V
Unlearning counter according OBD: 27
Fuel high pressure: actual value-FUP_FIL: 72.083 MPa
Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL: 00000001
Fuel level-FTL_CAN: 14 l
Fuel temperature-TFU: 62 °C
Fuel Metering Valve-VCV: 19.775 %
Fuel Pressure Regulator Valve-PCV: 38.029 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 79931.641 kPa
10117 - Fuel Pressure Regulation Valve 2 Control Difference
P229B 00 [104] - Pressure too High
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 60
Mileage: 213452 km
Date: 2018.11.19
Time: 13:18:55
Engine speed: 892.75 /min
Normed load value: 27.5 %
Vehicle speed: 3 km/h
Coolant temperature: 58 °C
Intake air temperature: 19 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.118 V
Unlearning counter according OBD: 15
Fuel high pressure: actual value-FUP_FIL: 48.187 MPa
Engine status-SF_ENG_STATE: PL
Fuel temperature-TFU: 6 °C
Fuel Metering Valve-VCV: 27.116 %
Fuel Pressure Regulator Valve-PCV: 0.000 %
Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD: 31555.176 kPa
Readiness: 0 1 0 0 0
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 BB HW: 6R0 907 379 AH
Component: ESP8.2i front H07 0001
Revision: --------
Coding: 330448E9437000BBCC2B12E4C2D800920C00
Shop #: WSC 00046 000 00000
VCID: 7F0710B2EAE6D2B7EC-802A
No fault code found.
Address 08: Auto HVAC Labels: None
Part No SW: 8X0 820 045 A HW: 8X0 820 045 A
Component: J255 Klima Manuell 0140
Revision: 0000707S Serial number: 03030005858844
VCID: 346D0F9E5720C1EF41-8060
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 218708 km
Time Indication: 0
Date: 2019.05.12
Time: 07:55:43
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 G HW: 8X0 907 063 G
Component: BCM PQ35 M 110 0655
Revision: 00110 AE
Coding: 0E000A2CA805F100201841E020000154538B6C0A01CF4122DC0887830045
VCID: 4085534ED3986D4FD5-8014
Subsystem 1 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8X0 959 655 A HW: 8X0 959 655 A
Component: Airbag10.41 H04 0008
Revision: -------- Serial number: 003JJ0039CR6
Coding: 30314539303330303034554A305238583053
ASAM Dataset: EV_Airba1041BPAAU210 001015
ROD: EV_Airba1041BPAAU210.rod
VCID: 48954B6EF3A8550F1D-801C
Crash sensor for side airbag: driver side:
Serial number: 3554VRB40570M8GC60TN
Crash sensor for side airbag: front passenger side:
Serial number: 3575HRB405J0OPMG2OOP
Crash sensor for front airbag: driver side:
Serial number: 3585HRB40510N3MG8OFP
Rear Impact Crash Sensor:
Serial number: 3515ZRB405B0MFP6I0U8
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 501 B HW: 5K0 953 569 H
Component: LENKS.MODUL 014 0140
Revision: FF010016 Serial number: 20110913100937
Coding: 1184004000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 39733EAAB8423C8792-806C
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8X0 920 980 D HW: 8X0 920 980 D
Component: KOMBI_MEDIUM H03 0179
Serial number: 00000000000000
Coding: 41DE00
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04390
ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: 4085534EDB986D4FD5-8014
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 A HW: 8U0 907 468 A
Component: GAT 4CAN 1L M H10 0044
Revision: 1P040023 Serial number: 2341P119180144
Coding: FBCF005A000100010153
Subsystem 1 - Part No SW: 8K0 915 181 H HW: 8K0 915 181 H
Component: J367-BDM H07 0171
Serial number: 00000000007100549523
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11278001482021200181
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H03 0179
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04110
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 D HW: 8X0 959 793 D
Component: TSG FA H09 0409
Revision: -------- Serial number: --------------
Coding: 011E02200101000100
VCID: 4E997D7619CC8B3F57-801A
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11251
Shop #: WSC 00046
VCID: 2F6700F2EA06E2373C-807A
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 D HW: 8X0 959 792 D
Component: TSG BF H09 0409
VCID: 4D9B7A7A14CAB0272E-8018
1 Fault Found:
02123 - Door Warning Light / Entry Light
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 218732 km
Time Indication: 0
Date: 2019.05.13
Time: 18:00:59
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8X0 035 183 E HW: 8X0 035 183 C
Component: RMC Cnct H51 0775
Coding: 01010001008051070023000103010000010000
VCID: 39733EAAB0423C8792-806C
Subsystem 1 - Part No SW: 8X0 919 603 HW: 8X0 919 603
Component: DU6 Basic H42 0084
Serial number: 9462IW0B0139570
End-------------------------(Elapsed Time: 02:41)--------------------------
www.Ross-Tech.com
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Mileage: 218826 km
Date: 2019.05.14
Time: 17:31:09
Freeze Frame:
Fault Priority: 2
Fault Frequency: 60
Mileage: 213452 km
Date: 2018.11.19
Time: 13:18:55
Revision: --------
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 162
Mileage: 218708 km
Time Indication: 0
Date: 2019.05.12
Time: 07:55:43
Revision: 00110 AE
Coding: 1184004000
Coding: 41DE00
Serial number:
Coding: 000002
Coding: 11251
Shop #: WSC 00046
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 218732 km
Time Indication: 0
Date: 2019.05.13
Time: 18:00:59
