A few question regarding my new car
drummerdimitri
So I picked up my car today and I must say I have fallen in love with it!
Will definitely be posting some pictures when I can but I have two questions so far:
1) I can't seem to locate the trunk opening button
2) How come the white led strip light doesn't light up at the back of the car on the B&O sound system? Only the speakers at the front light up so I wanted to make sure nothing is wrong here.
RichardT
Just above the number plate, next to the number plate light.
h5djr
Gold Supporter
There is no interior 'trunk' opening button. Open from the outside only.
Scottyg
What model and year of car do you have? My boot opening on MY15 car is from key fob only.
Scottyg
Also, is it headlight led strip you're talking about? If it is then they are DRLs and only the front light up.
RichardT
Surely there is a button by the number plate?
h5djr
Gold Supporter
Mine unlocks using the key fob, but I need to use the release button by the number plate light to actually open the boot.
h5djr
Gold Supporter
'drummerdimitri' - Which country are you in. I assume that by using the word 'truck' you are in the USA or Canada. If so remember that most of us on this thread have UK spec cars which may well be different to yours.
Scottyg
Mines unlocks from key fob and I can just lift the boot lid as its already released.
h5djr
Gold Supporter
If you just give a quick press on the button 'boot' button on the remote it will just unlock. If you press it for at least one second it will unlock and release the boot lid. If you just use the button to unlock the car itself it will either unlock the doors and boot lid (but not release it) or unlock the drivers door only depending on how you have it set-up.
Rob2k68
Well-Known Member
There is no rear B&O speaker light only the front has the LED strip so you do not have an issue they are all like that.
Rob2k68
Well-Known Member
You could also press the boot release button on your key fob when inside the car if you wish thinking if you had it set on the MMI that the key fob open only unlocked the drivers door and therefore requires a double press to unlock all doors.
Also the global unlock button by the door interior release handle will do the same job.
Blackwhite
I have a 2015 A3 Saloon. Mine opens by a knob on the inside ( left door
panel ), also the outside ( above license plate ) and also on the key fob.
DJAlix
VAG Car Coding™ Limited
Site Sponsor
Gold Supporter
VAG Can Professional
ODIS (Offboard Diagnostic System)
Looks like USA spec cars have an interior button also.
Saloons (all) will release and automatically lift / open fully if you press and hold the middle button on the fob.
drummerdimitri
That's a shame seeing that they both have the white plastic strip running across the contour. Would have been way nicer if the back had the lights too!
drummerdimitri
Looks like USA spec cars have an interior button also. Saloons will release and automatically open fully if you press and hold the middle button on the fob.
Interesting. I don't see why all A3's wouldn't have a boot opening button in the car's interior.
I guess I could just press the boot open button on the key fob if need be so not a problem.
h5djr
Gold Supporter
Yes I thought it a little odd when someone said it was in the left-hand door. Makes sense for a LHD car! Perhaps all LHD cars, even European ones have it but just not RHD-UK versions.
Rob2k68
Well-Known Member
I agree mate - I don't suppose they are the same shape otherwise we'd all be buying fonts to fit in the rear. To be honest theres so much fun to have in the front you won't notice it again :yahoo:
drummerdimitri
Maybe there will be a retrofit kit in the future but yeah so far so good. The car exceeded my expectations and that's in Eco mode while the engine breaks in! Just have to be really careful with potholes as the 18 inch wheels have barely any sidewall.
Vertigo1
That's what I thought. Pretty useless feature really unless the trunk has a powered closing feature.
Powered closing on saloon boots has to be the single most utterly pointless feature I've ever seen on a car. Ever.
The in-laws 5-series has it. Just what on earth? It's a useful feature if you have a hatchback or SUV with a large tailgate but a saloon? Seriously? So, rather than taking literally one second to shut the boot manually, which is not high up nor heavy, you press a button and then wait for at least 5 seconds for the thing to slowly close?
Annoyingly this doesn't work whilst the key is in the ignition. The only times I really want to open the boot remotely is when I'm pulling up to collect someone and want to open the boot for them so they can throw stuff in quickly/easily. In such circumstances the key never leaves the ignition so it doesn't work unless I physically remove it.
Beluga S line
In my A4 B8 Saloon I had a button inside that opened the boot. So they can fit it to a RHD car if they wanted to.It probably saved me all of two seconds. The only time it was a real benefit was if I was picking someone up and it was raining I just opened the boot so they could chuck their suitcase in. The benefit was that I didn't get wet...apart from that it's a nice gimmick!
Rob2k68
Well-Known Member
Doesn't the global unlock button beside the interior door release handle unlock the boot too so anyone needing access could do so ?
DJAlix
Site Sponsor
Gold Supporter
Yup
Beluga S line
It does...what I should have said on the B8 saloon the interior button throws the boot open! So you don't need to use the handle/button on the boot.
I think this is what the OP wants to happen!
Vertigo1
Yes it unlocks it but doesn't open it.
h5djr
Gold Supporter
Why do you need it to open ?
Perhaps with all the new Driver Assist system on the A3 everyone is getting to lazy to open it themselves. I have a hatchback and I'm also 67 years old and not in the best of health but I can still manage to open mine without any problem.
Vertigo1
It's useful on the saloon as you can remotely open the boot and it will actually pop fully open, easing access for someone else whose hands may be tied up with luggage/shopping/etc.
On the hatch it's next to useless as the remote open just makes it pop ajar slightly, you then still have to lift the tailgate open as the gas struts aren't designed to lift it open from the closed position.
Rob2k68
Well-Known Member
The self opening its easier to implement on the design of a saloon using a torsion bar system as an assist directly on the swan neck hinges.
On a hatchback the popular solution is to use powered electronic struts in place of the regular gas strut which are a much larger diameter and would compromise the width of the load space opening.
Vertigo1
It's also dangerous having a large tailgate pop open automatically as there's the potential for damage with low ceilings such as in some car parks.
h5djr
Gold Supporter
I've had to stick a large foam pad to the inside of my garage door so tha,t when I open my tailgate with the car is in the garage, it does not hit the door, metal to metal.
