Hello People!
Well recently I purchased an Audi A4 B7 2.0 TDI - 2005 plate - Its my first Audi so as you can imagine I was very excited.
After a few months of ownership I have run into a few problems, I have some really bad luck and all iv'e had is problems after problems!
So far I have the following
1.The buzzer no longer works. This normally comes on when you don't have the seat belt on or when you have accidentally left the lights on when the keys removed from the car. I have left my lights on so many times!! so this is really annoying!
2. Today the key fob stopped working. It no longer locks or unlocks the car. And I only have one key. I have changed the battery on the fob itself and I can see the red light come on the fob when the buttons are pressed - But I am still getting no response from the car, you normally see the hazard lights come on when buttons are pressed
3.The car is showing a check engine light, I have borrowed one of those Bluetooth scanners to get some codes off, not to sure how accurate they are but I have the following codes
P2108 -which I think is the Throttle Actuator Control Module Performance
P0236 - not to sure what that is.
4.I am getting right dipped headlight message as well as rear reverse light error when reversing. The bulbs have been changed -same problem. I have noticed all i need to do is wiggle the bulb wiring and the error code goes, but after some time it comes back - the contacts have been cleaned so not to sure what else it could be.
Any suggestions and advice would be great, as I am really losing hope in this car
Qasim
Qasim
