I've looked at various threads, tried various things. But I can't seem to get rid of these 2 errors in the 03-ABS and 17-instruments module. I've managed to get the TPMS menu to show in the MMI.
Original coding for ABS:
31FF6B9254200A72017B030741CC698CD62A5080C08296B6184150040208
Auto-scan
Auto-scan
Code:
Saturday,20,January,2018,20:51:23:37550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.1.0 (x64)
Data version: 20171130 DS276.6
www.Ross-Tech.com
VIN: License Plate:
Mileage: 29285km-18196mi Repair Order:
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 3C 42 44 47 52 55
5F 6C A5 A9 BB BC
VIN: xxxxxxxxx Mileage: 29285km-18196miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 0A1D00122466000E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H.rod
VCID: 458A5C27C433486EE2-8010
No fault code found.
Readiness: 0000 0100
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4931
Revision: 06253104 Serial number: TFK01604150540
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021_VW37.rod
VCID: 53AE727F3A67E6DE7C-8006
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60946000002438
Coding: 31FF6B9254200A72017B030741CC698CD62A5080C08296B6184150D48208
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
VCID: 7AF0FFDBFD4DF796DF-802E
1 Fault Found:
8216 - Databus
U1121 00 [009] - Missing Message
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 29285 km
Date: 2018.01.20
Time: 20:29:02
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0400786725
Coding: 030C0C
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002_VW37.rod
VCID: 3A703FDBBDCD37969F-806E
Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
Part No SW: 8V0 820 043 D HW: 8V0 820 043 D
Component: AC Automat H14 0060
Revision: 20028000 Serial number: 00000000921862
Coding: 03000014010000000000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008020
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 336E12FF9AA7C6DE5C-8066
Relative humidity sensor in fresh air intake duct:
Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H03 0005
Serial number: 95C9C32800PAG0MUFU01
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 085 BL HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061611100686
Coding: 04151C46C04106FD41C04004511807A00800000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015_VW37.rod
VCID: 040C81238F89B166B5-8050
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 160416 043 0585
Serial number: 160425133137
Coding: 0A47F7
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 61697322
Coding: 02006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AA HW: 8V0 941 531 AA
Component: E1 - LDS MQB H05 0032
Serial number: 26 01 2016 00001553
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000065662772
Sun Roof:
Subsystem 5 - Part No SW: 8V3 959 591 A HW: 8V3 959 591 A
Component: J245 PS73.404 H03 0004
Serial number: 0000FST000WWQZH00000
Coding: 101F00
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331611407116
Coding: 0070150011
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 438E423FCA07765ECC-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-567.clb
Part No SW: 5Q0 907 567 N HW: 5Q0 907 567 N
Component: ACC3 H10 0400
Serial number: 27041603091714
Coding: 01261701FE0309
ASAM Dataset: EV_ACCBoschMQB 001024
ROD: EV_ACCBoschMQB_AU37.rod
VCID: 46885B2BF9354376EB-8012
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR04SMWF
Coding: 9DCCFCC0000000005000001AC24800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002144
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 4796562FFE3F5A7E10-8012
Belt Pretensioner left:
Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B
Component: BeltPretRevFL H36 0350
Serial number: 34230167A02051651222
Coding: 333135
Belt Pretensioner right:
Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B
Component: BeltPretRevFR H36 0350
Serial number: 34230168A03051650024
Coding: 333135
Occupant Detection:
Subsystem 3 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
Component: BF-Gewichtss. H10 0046
Serial number: 694000000000001GRXPZ
Coding: 303334
Side Sensor Driver Front:
Subsystem 4 - Part No SW: ----------- HW: 480 002 504 16
Component: SideSensor_Df 001 0887
Serial number: 35700000000FC5C4BA1%
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 5 - Part No SW: ----------- HW: 480 002 504 16
Component: SideSensor_Pf 001 0887
Serial number: 35800000000AC5C4BA1
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 401 604 16
Component: SideSensor_Dr 001 6149
Serial number: 3510002BF2057282712U
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 7 - Part No SW: ----------- HW: 480 402 504 16
Component: SideSensor_Pr 001 6149
Serial number: 3520002A920414E0422L
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 8 - Part No SW: ----------- HW: 480 400 604 16
Component: FrontSensor_D 001 6149
Serial number: 35500029F20179E47322
Coding: 2D2D2D
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 400 604 16
Component: FrontSensor_P 001 6149
Serial number: 35600029F20179E433B8
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 8V0 953 521 GR HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 25041604401214
Coding: E818
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_020_AU37.rod
VCID: 1024BD73CBF1DDC601-8044
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 8V0 920 872 A HW: 8V0 920 872 A
Component: KOMBI H03 6423
Coding: 038D181B6F8800080281EA001800000000000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_DashBoardVDDMQBAB 009051
ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
VCID: 3B7E3ADFB2F70E9E84-806E
1 Fault Found:
16776973 - Databus
U1121 00 [008] - Missing Message
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 120
Mileage: 29242 km
Date: 2018.01.19
Time: 20:57:29
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 29041610800172
Coding: 0101000830085A005B00023C180B00000001010000000000000000000000
ASAM Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013_VW37.rod
VCID: 79F2E0D7F84BFC8ED6-802C
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 8U0 951 528 C HW: 8U0 951 528 C
Component: E221 - MFL H02 0014
Serial number: 16 04 2016 E0054200
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00002.04.16
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
VCID: 4A906F1BED2DA7160F-801E
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000074712010
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB_004_VW37.rod
VCID: 346C11E39FA9C1E645-8060
Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
Part No SW: 5Q0 907 566 A HW: 8T0 907 566 B
Component: SWA Master H07 0080
Serial number: 0400666804
Coding: 030211
ASAM Dataset: EV_LaneChangAssis 001020
ROD: EV_LaneChangAssis_VW51.rod
VCID: 387425D383C1258669-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 568 A HW: 8T0 907 568 B
Component: SWA Slave H07 0080
Serial number: 0401218583
Coding: 030211
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 140416EDD0660A
Coding: 005D1B204000048000000003
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 9102
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB.rod
VCID: 397220D7B8CB3C8E96-806C
Address 47: Sound System (J525) Labels:* None
Part No SW: 8V0 035 465 D HW: 8V0 035 465
Component: MIBAMP1ALPINE H11 0420
Serial number: AUZ8ZAGN9026NH9
Coding: 01030300AAAA2AAA01
ASAM Dataset: EV_AMPMst16C1ALPI 004024
ROD: EV_AMPMst16C1ALPI_004_AU37.rod
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 140416EDC09017
Coding: 005D13204400048000000003
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
VCID: 4280473BD51D7F56C7-8016
Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Revision: -------- Serial number: --------------
Coding: 012A000123200400
ASAM Dataset: EV_HeadlRegulAFSMQBMLB 001001
ROD: EV_HeadlRegulAFSMQBMLB_AU37.rod
VCID: 3F864ECFA6EF12BEA8-806A
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E00100
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E00100
Left Headlamp Power Output Stage:
Subsystem 3 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo links H01 7050
Coding: E00100
Right Headlamp Power Output Stage:
Subsystem 4 - Part No SW: 7PP 941 329 M HW: 7PP 941 329 M Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 7050
Coding: E00100
Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
Part No SW: 8V0 035 047 C HW: 8V0 035 047 B
Component: MU-H-NS-US H44 0403
Serial number: A052D0G7512786
Coding: 017301020000000021220002041A00002F000224010001047E
ASAM Dataset: EV_MUHig6C3HBAS 001040
ROD: EV_MUHig6C3HBAS_AU37.rod
Data medium:
Subsystem 1 - Part No SW: V03 959 800 T HW: -----------
Component: NAR 2016 --- 0048
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9GY205C33
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 L HW: 8V0 919 614 L
Component: ControlUnit_H H81 0816
Serial number: ALJAL107031600020055
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote --- 3006
1 Fault Found:
0020 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 82
Mileage: 29285 km
Date: 2018.01.20
Time: 20:11:32
Voltage terminal 30: 14.7 V
Satellite radio tuner status-Satellite radio antenna status: Electrical OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: weak_signal
Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 5Q0 907 441 A HW: 5Q0 907 441 A
Component: MQB RVC Mid H07 0140
Coding: 027300010201000300
ASAM Dataset: EV_2CamSysRearPASE 006016
ROD: EV_CamSysRearPANAVW428.rod
VCID: 30641DF36BB1FDC621-8064
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H07 0060
Serial number: 10000545445
Coding: 0100000000010303000500010100000100
ASAM Dataset: EV_MFKBoschAU370 001001
ROD: EV_MFKBoschAU370.rod
VCID: 3C7C39C3B7F909A68D-8068
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 8V0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0012
Serial number: 160305202088
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X_VW26.rod
VCID: 7DFAF4C7EC63C0AEFA-8028
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 395 E HW: 5Q0 959 395 B
Component: TSG HFS 020 0041
Serial number: 170416EDF34691
Coding: 004D13204000048000000002
ASAM Dataset: EV_DCURearDriveMINKLO 006003
ROD: EV_DCURearDriveMAXCONT_VW37.rod
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 170416EDG03042
ASAM Dataset: EV_DCURearPasseMINKLO 006003
ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 05:49)--------------------------
