  2. Dismiss Notice
8p3 adaptive xenons
thesmileyone Dec 25, 2017
  1. thesmileyone
    thesmileyone Registered User
    557
    56
    Are these supposed to move from side to side?
    Test drove a car in the dark the other day, they didnt move. Guy (audi dealership) said they dont move from side to side, they "have extra lights that light up as you go round corners".
    Im sure these are supposed to move from side to side?
    They are ECE patterns so I hope so!
  2. Avatar
    snack-media
    Advertisement
  3. Darren92
    Darren92 Registered User
    2,473
    652
    Not all cars have adaptive. If they only moved up and down then it’s normal bi-xenon.
  4. S.
    S. Save the manuals
    2,333
    697
    That headlight from the picture should be adaptive headlight. Black xenon lense side cover is non-adaptive.
    I've driven a car with adaptive headlight and i had a hard time noticing them move but they do.
  5. SteveMcB
    SteveMcB Registered User
    1,001
    602
    They do move with the wheel above a certain speed, on the SQ5 the light switch has to be in 'auto' though.
  6. thesmileyone
    557
    56
    This car doesn't have light sensor, but I did have them set to headlights and not left on DRL. Unless there's a sensor seperate to the one which comes with the auto dimming mirror which it does not have?
  7. NHN
    32,315
    2,512
    You only notice them at slower speeds, drive around some A roads & you'll notice on slower turns & no they don't have extra lights inside for this, there are additional motors that swivel the light left & right aswell as the standard bixenon motor for up & down.
  8. -Ju-
    -Ju- Well-Known Member VCDS Map User
    3,663
    1,548
    Are they not supposed to do the down/up, left/right check on start up like on the 8P2 if they are adaptive?
  9. NHN
    32,315
    2,512
    up & down yes.
  10. -Ju-
    3,663
    1,548
    I'm sure my 8P2 with adaptive did the left right shuffle too, are the 8P3 different?
  11. NHN
    32,315
    2,512
    They didn't always do l&r, if adaptive were faulty on the car in question, a fault would show in the dis, it's merely knowing when they will be used & noticeable.
  12. Avatar
    snack-media
    Advertisement
  13. SootySport
    SootySport Registered User
    4,229
    1,140
    I have a 2010 adaptive lights, bixenon. They only go up and down on start up and move left/right when turning corners above 15km. Per hour. The fogs don't don't light up at all on turns. You'll notice them turning on unlit roads more than in town.
    Fog and DRL come on as "coming home lights"
  14. thesmileyone
    557
    56
    I hope they work. Where I live there are lots of 90 degree corners on lanes as well as the same corners up and down hills.
    On my old car with projectors and ece beams they were fixed both up down and left right and used to blind oncoming traffic going round left hand bends uphill etc. Granted they were the full 85w ones and these are limited to 35w (thanks, EU!) but I will probably convert them to morimoto projectors eventually for the full 85w output.
