8p2 Bi-xenon retrofit help, DRL not working
BennyG_UK
Top Gear
Bradford, UK
Hi Guys,
I did the Bi-xenon retrofit quite some time ago but never got the DRL's to work.
I followed all the guides in terms of VCDS coding to no avail.
Ive converted from halogen and used kufatec adapters. If i don't choose bi-xenon in vcds and use the full beam flasher, the bulbs flash as if they're full beam's and the shutter doesn't operate (expected) so I know (or I think) they're wired in correctly.
Ive still got standard headlight switch installed no DRL button.
CE module version below:
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Everything works apart from the DRL's lol
Any ideas?
Change the switch . ? Could be wrong not looked at the halogen wiring schematic . But on the xenon one there.is a.specific wire for the xenon with drl only.
The switch is the only thing I can think of. I have enabled Scandinavian DRL's so thought this would get around needing the switch.
Its a coding issue. As long as you have wired it all in properly then its not the switch. The DRL switch is not needed to activate the DRLs
Well thats what I was thinking but I've followed all guides in regards to coding and even went through it all to check I have missed any hidden bits to enable etc.
Ok I just noticed something that I missed earlier... You said that you have the C Rev CE module... For bi-xenons you need to have the F or K. C does not have the code for Bi-Xenon
Thats odd as it has all the options there for Bi-xenons. Is it plug and play change over (obviously with coding) or do wires need changing too
No worries will do. Il keep an eye out for a cheap module and take it from there. Cheers pal
