G60 Flywheel & VR6 Clutch???
Mr.Blonde
ESSEX
Hi,Ive read up that some of the Golf 1.8T boys with a remap fit the G60 flywheel with the VR6 clutch??.anyone done this or know more about it?.
Hi Steve, I'm running the g60 flywheel and VR6 clutch in my A3, and it's brilliant.
The standard G60 flywheel weighs 10kg, which is already lighter than the dual mass standard flywheel, and would make a good difference.
Mine has been lightened down to 6kg, and it's absolutely great.
I'm using the LUK VR6 clutch kit, which mates directly to the g60 flywheel, and is rated to just over 300lbft.
You also need the g60/ABF flywheel bolts, as the standard ones are the wrong length.
THe flywheel you need is often refered to as G60, but it's also the same as that fitted to the ABF engine, which is the 2.0 16v fitted to the mk3 golf gti.
All in all, it's super cheap to do, around £100 for the flywheel brand new, £100 for the clutch kit, and I paid £100 to have it all lightened and balanced.
The difference is great too, it picks up a LOT faster and feels way more responsive. it's also a really nice pedal feel, and not bitey at all.
Prawn sounds great mate,have you got the part numbers for the clutch etc please or where to get it all please dude?.:)
not got any part numbers dude, they're not really needed.
Walk into a VW dealer and ask for an ABF flywheel and bolts
then walk into GSF and ask for a clutch kit for a golf VR6.
job done :)
Would this be of any benefit on a 1.6 A3 or a waste of time and money?
Cool beans Prawn.So you reckon around £200 for the clutch and flywheel?
Is this set up recomendable for an s3? Im getting mine remapped soon and my clutch has done 103k,so i need to look into a good set up should my clutch go.
No idea on the S3 mate as it has a 6-speed box so dont know if it has the same set up.
no, sadly it won't fit the S3 box I'm afraid!
Steve: I'd really look into getting it lightened if I were you!
it makes such a big difference, with no downsides at all
The 6 Speed cars (A3/S3) have a 240mm clutch/ flywheel where as the G60 combo is only 228mm so will not work
Is there anyway i tell if it is the right flywheel from a G60 as ive been offered a few flywheels from the ABF??
if its from a ABF then it will fit. you can use a G60 or a ABF flywheel but not a VR6 one (they have a different blt pattern)
So what cars have the ABF flywheel mate?..i know the G60 % MK3 16v have it,ive also heard that the passat has it to??.
G60 is the engine used in a Golf Mk2 G60 (suprisingly) and also in a g60 passat and anything else g60 powered
ABF is the engine code from a Golf Mk3 16v GTI and again its used in a Passat and also some Ibiza's (anything mid 90s FWD VAG group 2.0 16v basically)
will this work in a T reg 1.8T as im really considering it?
Hello Mate
I fitted this setup a few months back and it’s progressively got worse and worse. I can’t chnage gears with out a crunch. Almost like the clutch isn’t disengaging. I have resorted to double clutching to stop this. I’m thinking of going back to OEM with a updated clutch. Any thoughts? =]
Hello Mate
Hi mate it could be your clutch fork that's fatigued and split/bent. It happened to me a few years ago within months of fitting the G60/Vr6 setup.
Interesting, is this an easy chnage for a competent diyer... =]
NICE! Looks like I shall be trying this at the weeeknd. =]
Thanks for the help as always!!!
if you can change a clutch you can change the fork... gearbox off job
Tuffty, you’ve sent me a how to guide before for a slave cylinder. Can you give me a link for a the gearbox removal how to... =]
PalmCon 1
Reactions: SHUk
Erm..:
if you google google the internet breaks - #fact
Reactions: SHUk
D
584
Deleted member 65282
D
