I forgot to mention that I will be using a Gen 1 TT 3.2 ECU BUT DARN THING WAS A DSG
Not sure that makes a difference other than you might need to flash an R32 (manual) map on instead... not something I have had to deal with as I am using Ignitron ECU...
1) I am also planning to use the S3 standard 14pin plug with the 3.2 engine side connecting to it. So I just want to make sure that I must take the speedo cables out my original harnness and tap it into the 14pin plug? I think there are pins in the way though, any ideas on that?
I am using the larger 81 pin loom from the S3 and the smaller 40pin loom from a 3.2 TT... please note however I am able to do this as I am using an Ignitron standalone ECU and not an ECU from an R32/TT 3.2 as I couldn't tell you if the std S3 ECU is compatible in so much as I don't think you can flash an R32 map on to it...
Ignitron supports using a feed from the ABS for the speedo signal but I decided to use the speedo drive from the box and ran the wires to the 14 pin plug
2) Pin 1 on the Fan control module is the the wire that controls the After run pump on both the 1.8t and the constant run pump on the 3.2.. I do not understand 100% what you meant when you said: " I just took the original pin for the S3 after run pump... only reason I re-pinned was down to the VR pump seemingly running a thicker gauge wire so I had a spare wire available so used it... the TT loom had the correct plug etc for the after run pump so I just left that as is... ". Does that mean nothing needs to be done for this pump or what should I do?
As you are using an OE ECU you might find you need both looms to get it to work but tbh I couldn't say off hand what the differences are as I wired mine for use with the IECU...
Using IECU for a turbo build will give you more control, better protection and is much easier to tune plus you can go properly MAF less which is a great advantage on builds like these... it only supports one Lambda currently though so running NA means I have to be creative ( I currently have the lambda in the downpipe for cyl's 1,2,3) but ultimately it runs fine for now... if I was sticking to NA and using IECU I would however move the lambda to a more central point where it will see exhaust gas from all cylinders
So gearbox has arrived... sadly has the excessive play problem :(
Measured 2mm of play on the input shaft which is not the best... the seller has been contacted to see where we go from here but... the gearbox/clutch saga continues.... ***!
Ah ***, that's rubbish. Why can't people check things over before they sell them; do they not expect buyrs to check?!
It was 'test driven with no issues'... which is about as much use as 'my mate done this' replies on the interwebs...
The have organised a pickup to return... I have officially called it faulty (as they said no need to raise a return but I did anyway) and I have a concern that I won't get all my money back but at least thats (mostly) sorted... just need to find another box...
Always worth going through the "proper" channels with random sellers in my experience. PITA regardless though.
Started the day with an aircon re-gas...
20190928 96dpi IMG 20190928 094612
...however.... always a bl**dy however these days!... pressure seems to be holding ok but the air wasn't cold in the least... and then noticed the larger fan wasn't turning... which was followed by a familiar smell... the smell that means the magic blue smoke has escaped :(
On further inspection I could see that the aircon hose had moved and was pressing on the fan... disappointing... so will need to deal with that and potentially replace the compressor... which is fine as I have a couple of spare ones...
So parked her up on the naughty step again and took the A2 off for a jolly to Basingstoke to pick up this...
20190928 96dpi IMG 20190928 155001
...yep... another gearbox lol... this one however is a DRP code so a proper box...
20190928 96dpi IMG 20190928 155832
Early non black cap one and was a relief to grab the main shaft (fnarr) and not have it move in and out (again, fnarr)
I also managed to bag a set of 4-Motion PAS pipes... this is a full set which doesn't have the oil cooler the 20v uses but the plan is to use the bits I need to get the pipe out of the way from getting damaged and will use the cooler kit I bought too...
20190928 96dpi IMG 20190928 155819
I plan to strip this box, to inspect it clean it all up and do the mods to the forks... I'll most likely paint it too if its ok
Fingers crossed this marks the end of my gearbox and clutch woes...
Reactions: DCH and killfame
What exactly you plan to do with the forks?Just strengthening the weak spots of the genuine ones or going for uprated ones and which manufacturer, if so?
Started off by draining the oil out of the box... oil came out nice tbh... was translucent and no shiney bits...
20190929 96dpi IMG 20190929 103858
Split the case.... no lumps of metal, no obviously excessive wear marks so all looking good so far...
20190929 96dpi IMG 20190929 132545
Removed the internals...
20190929 96dpi IMG 20190929 132550
...cleaned the case halves...
20190929 96dpi IMG 20190929 140239
..and the internals...
20190929 96dpi IMG 20190929 143031
Next I modded the forks to address the common rivet failure problem (I did this on my 20v box so have a look on page 90 for more detail...
20190929 96dpi IMG 20190929 151951
20190929 96dpi IMG 20190929 155123
20190929 96dpi IMG 20190929 162646
Fitted all the cleaned internals back to the bellhousing lubricating up with gearbox oil...
20190929 96dpi IMG 20190929 163459
20190929 96dpi IMG 20190929 163517
Applied sealant and bolted the halves together... and done :)
20190929 96dpi IMG 20190929 183545
Hopefully this marks the end of my gearbox and clutch issues... (once I get around to fitting it of course)
While I was getting the box I also managed to grab a set of 4-Mo PAS pipes as while the 20v ones do fit and 'work' there are clearance issue... I already had to extend the feed pipe to get it close to clearing the alternator pulley but its still not 100%... also the pressure pipe off the pump sits way too low and I have already caught it so its just a matter of time...
The pipes look a bit different...
20190929 96dpi IMG 20190929 185032
20190929 96dpi IMG 20190929 185037
I only need the feed hose from the reservoir and not the return pipe with the curly bit on the end as the 4-Mo doesn't have a fluid cooler loop like the 20v and I want to retain that especially once turbo'd... I have the PAS cooler to fit for that as you may recall the std 20v cooling pipe doesn't really fit nicely either lol...
I wire brushed the pressure pipe and while a little pitted its in decent condition so I will clean off the existing paint, blast it and repaint...
20190929 96dpi IMG 20190929 190611
That should hopefully sort all the PAS pipes and give me decent cooling...
Next job is to replace the cooling fan (and sort out the aircon pipe to stop it happening again) then swap out the aircon compressor which I hope will sort the aircon issue... while I await a ramp so I can swap the box out I need to order another slave and more oil...
Joys of modding cars... hopefully now though anyone reading through this will be a little better informed than I was when I started this undertaking... (you are welcome lol)
Reactions: JOSE8LT and ADs3
Lovely stuff PT! your gearbox issues remind me that I'm not alone :laugh:
Hope that stock 4th holds out for you when it's turbo'd!
I rarely get out of third when in Mexico tbh but I am well aware of the limitations there... Once I have sorted out the rest of my gearboxes (have now been refunded for the last one) I will acquire another spare as a just in case...
As I am still running std rods (will have ARP bolts though) I will play with tuning so its less stressful on everything...
The first hurdle of course is getting the car actually drivable... to be clear the issues I am having are more related to worn parts, incorrectly supplied parts and minor issues related to engine swaps (aircon pipes, PAS pipes etc)...
This info is either pretty thin on the ground or ambiguous at best so hopefully I can at least answer a few of those doing this :)
This thread is by no means definitive and more my experience with how I have gone about it...
Modding cars beyond what is considered 'bolt on' is always a challenge but fitting a gearbox isn't a challenge I was expecting to deal with much like yourself... onwards and upwards though dude :)
Reactions: Prawn
What sort of ballpark torque do the VR6 rods tend to take? Not sure if the rods themselves are much different to those fitted to the 1.8t (obviously there are 50% more of them and things should be a smidge smoother). Glad to hear you've sorted a refund on the dodgy box. PITA regardless though.
You say this isn't a definitive guide but given your signature attention to detail it should be a good reference for people if nothing else.
Reactions: <tuffty/>
A bit different yeah... ironically not drilled either...
Screenshot 2019 10 02 at 132740
I was running 155hp/110flbs per cylinder in the 20v... not sure what the power output is likely to be as this is the first VR setup I have done but it 'should' be in the region of 400-500hp so thats 66-83hp per cylinder so at my assumed rev limit of 7k in theory thats 50ftlbs to 62ftlbs per cylinder...
Assuming the math works out (who knows) then I am hoping stock rods should be good for that... the figures that get interweb'd about is the usual horsepower and not torque figures and seems to be anywhere from 400 to 600 hp...
I plan to be a bit more progressive rather than aggressive with the mapping so will see how that works out...
Yeah, grateful that the process was fairly painless tbh.. they arranged pickup but have refunded via eCheque so have to wait a few days...
Thanks dude... appreciated :)
The wife is a bolton fan... should have been a sign really but we have put up with each other (well, she has put up with me I should say) for 30 years now lol
Reactions: Rainbird
A little update....
Following on from the rather dramatic fan not turning incident I found that it was not turning as the aircon pipe was resting on it :(
So... I got the system degassed as I need to swap out the pump and took the front off to have a butchers at the fan...
20191027 96dpi IMG 20191027 102807
...the pump looks fun to do :
20191027 96dpi IMG 20191027 103953
...then I saw this.... epic fail :(
20191027 96dpi IMG 20191027 104121
Well that made the decision on removing the pump easy lol... will leave it there for now until I can work out what to do next with the pipe...
I then took the fan apart as it smells a little toastie... and yep... it was a little melty..
20191027 96dpi IMG 20191027 111520
20191027 96dpi IMG 20191027 111602
Unfortunately the spare fan I had was the wrong side... so had to order a new one... never ends lol....
To get the car down to my mates place for the de-gas I used a tactical piece of wood to move the hose out the way... so decided to make a better more permanent version...
20191027 96dpi IMG 20191027 125324
Siliconed and screwed the block on and....
20191027 96dpi IMG 20191027 131746
....seems to work...
20191027 96dpi IMG 20191027 132547
20191027 96dpi IMG 20191027 132622
I guess I will need to find replacement air con pipes but of course this is the one that is one piece from the front to the back.... so that will be fun to fit (said no one ever!)
I will also see if I can find someone who might be able to replace the hose if I can get the car to them and take the front off (getting pretty good at this now lol)... I will probably go through winter with no aircon anyway now... not got the motivation to swap out the aircon pipework if thats what I end up having to to...
Once the car is 'mobile' again all thats left to do then is swap the new gearbox in... hopefully a ramp will be available soon as the winter months close in lol :)
<tuffty>
Reactions: Tj 0785, Method and hawesy25
Why can't you just do away with the aircon? Or would that not solve the problem?
I want to retain the aircon.... I don't do heat very well and not a fan of opening the window (makes a mess of my interior lol) so while removing it would sort the pipe issue its not a solution for me...
The V6 pipework is a little different... there is no great rush to sort it though unless I can get the hose replaced without replacing the whole lot... I may look into getting hold of a 4-Mo setup or V6 TT maybe... will see what comes up over the coming months...
The existing 20v pipework will be fine with tweaking, I am just a bit annoyed with myself that I didn't notice it before...
Reactions: yoursixx
Probably a good idea, for when you shift down instead of up... I hear that happens inadvertently at your age sometimes :p
In fairness I am more likely to lose bladder control than anything else these days
Reactions: Erikn89nl
Got access to a ramp Saturday (thanks Bill)... took me a while to get motivated tbh as after a few attempts at trying to sort the gearbox/clutch situation had not gone well and lets face it, dropping a quattro box is not the most fun thing in the world to do..
As is the way of my luck so far the day started well... and by well I mean one of the subframe bolts pretty much fell out when I unscrewed it... seems that the subframe fixing has seen better days...
20191102 96dpi IMG 20191102 105532
20191102 96dpi IMG 20191102 110600
...disappointing...!
...will deal with that later... so... here we are again... the R32 box is out...
20191102 96dpi IMG 20191102 131217
The R32 box (left) and the 4-Motion DRP box (right)...
20191102 96dpi IMG 20191102 142130
Took the slave out from the R32 box...
20191102 96dpi IMG 20191102 210618
Brand new from the last time the box was off... and still getting damaged some how... so Alex and I took a little time to do measurements between boxes, plates, DMF's etc.... the only measurement I couldn't do at the time was to check flywheel face to block distance as all the other measurements seemed to be the same between a 20v and this setup...
We then looked at the plates themselves... there was evidence of the nose of the Sachs plate having touched the inside of slave which would explain the damage and cause of the slaves getting wasted... what was not easy to deduce is to why the nose would even be doing this in the first place as this setup is tried and tested in 20v's and our measuring suggests that everything should just work...
Alex grabbed an old plate that was kicking about the workshop and I noticed that there was a machined rebate in the nose that mine did not have.... I didn't take pics of the nose of mine sadly but here you can see the rebate on the old plate...
20191102 96dpi IMG 20191102 181338
Took some measurements of the inside of the slave guide sleeve and it was around 0.5mm smaller than the nose of the Sachs plate so Alex put the plate on the lath and tuned a rebate into the nose of it... the plate now sits flush to the release bearing face (would never get that close in use due to the cover plate fingers and included a little wiggle room... it actually didn't require much material removing so won't compromise the integrity of the plate..
I didn't take any pics for some reason but tbh its not really a DIY mod as using anything other than a lathe could cause problems if not perfectly round...
With that done I refitted the clutch and then the 4-Mo box... I used the transfer box from the 4-Mo too as it kinda made sense to keep them together.. the R32 transfer box will be kept as a spare
20191102 96dpi IMG 20191102 161027
...and now for the job I have been putting off.... ideally I would weld a replacement captive 'nut' in but that would require pulling up the carpet and no doubt a little cutting the floor about to sort out so I went for a helicoil on the basis there was an M12 kit at the workshop and whatever I did would be better than no thread at all...
20191102 96dpi IMG 20191102 161010
Drilled and tapped.... tapping was a little hard going... had to back out a few times to clean off the swarf as the usual cut and back motion was enough... was worried it would hang up and either snap the tap or literally pull the fresh threads back out!...
20191102 96dpi IMG 20191102 170503
...however it went ok in the end and got a helicoil in...
20191102 96dpi IMG 20191102 171158
Torqued up the subframe bolts to 100nm +90 (ish) and was a little more cautious on the helicoiled bolt but it took as much of the 90 degree as I felt comfortable doing and didn't feel like it was 'going soft' but time will tell of course and I plan to do something better next year (assuming it hasn't failed in the mean time)
All back together and filled with (yet more) gearbox oil... bled the clutch and all felt good...
20191102 96dpi IMG 20191102 204207
Got the old girl re-dressed and backed her out the unit...
20191102 96dpi IMG 20191102 205139
Had to get some fuel on the way home and popped to the Shell garage... they are doing roadworks on the roundabout there and they must have used some loose road filling material as it was dark and I rode over a trench crossing the road with a bang big enough that it opened my door!... I honestly thought I was going to find dents in the bonnet from front strut tops!!
Thankfully it seems there were no dents and the wheels still looked round! phew!..
I can report that I managed to drive home with no clutch issues at all... I even had a bit of a spirited burst changing up and down through the box with ease... who knew that could be a thing! lol..
Jury is still out... I need to put some miles on before I am 100% convinced but... I now believe the Sachs plate and 4-Mo DMF is most likely the cause of my problems so far in so much that (and this is informed speculation) the 4-Mo DMF sits the clutch plate a little further away from the engine (closer to the box/slave) and the nose of the Sachs plate while not an issue on the 20v application its designed for is just long enough that it interferes with the slave...
A std clutch plate does not protrude like the Sachs plate does so would not be an issue if using a std friction disc... the machining of the nose appears to have fixed the issue here and the R32 gearbox issue with the input shaft play was a bit of a red herring... there is more in/out play than there should be but its no different to any of the other boxes I have since looked at...
Hopefully the clutch is sorted out now, I am not really too surprised that I needed to do a little extra work to get all the clutch parts to work... its not the first time that a mix and match of parts needed fettling to work but at least I now know (and of course so do you)
Time to actually drive the car and I need to get a front alignment done now the subframe is not due to be off (hopefully) anytime soon...
Last main part of the turbo conversion should be sorted soon... ... I was going to use the R36 shells that everyone tends to use but ACL do coated big end bearings so will probably go with those...
There are a few other little things to sort out like downpipe bends and other stuff but these are all in hand...
I need to get the hot side separated on my GT35 so I can clock it correctly but this is proving a little tricky as its pretty much holding in there... I don't want to apply loads of heat in case I heat it up in the wrong place and nuke the bearing packs... all jobs for the winter though :)
Reactions: Cbax, Alex C, Tj 0785 and 3 others
Glad she is finally coming together sir!
So I am sitting at my next stand still.
Using a BHE motor + DRP box + MK5 R32 DMF, clutch and pressure plate. That darn spacer plate between the box and motor is needed or the pressure plate squeezes up against the face inside the box and everything locks up.
3 week order cause South Africa sucks like that.. Wrong parts arrive cause South Africa sucks like that.. 2 Week "flash order" for the correct parts cause South Africa sucks like that..
I feel your pain dude...
I have a bunch of parts I can sell to get some money back now at least... did debate on keeping the R32 box as a spare but if I do manage to nuke the DRP I might even consider looking at a DQ500 just because lol...
I can report that I have been driving the car a bit this week... so far all is good with the clutch... I'd be tempted to use two plates maybe but turning the clutch plate seems to have sorted things out for now...
I have just played catch ups on your VR6 turned into gearbox woes thread.
Looks like you're at the home run now!!! Not sure why i got so lucky with how generally "smoothly" my setup went but i just remember that everyone i asked said use the FW & clutch kit for that gen. gearbox. So since i was using the DRP/ 4mo box (not R32 mk4 one) that's the FW/clutch kit i went for.
re: Shredded A/C line - sorry i should've warned you on that one! Mine did the same and i just zip tied it away from the fan edge onto the dipstick tube.
Almost there!
How's it feel to drive?
how come you decided to use the mk5 dmf,clucth and pressure plate? Are you going turbo aswell?
Seeing the trouble your have I’m kinda glad I’ve been dragging my heels , nice to see it all come together, I need to really get a move on with it, it’s just depressing having the car sat there knowing I’ve got the all the gear,
If I had fitted a std clutch plate it would have been fine... it was just that the Sachs sticks out a bit and I think the VR DMF moves the plate a little closer... not an issue for a std style plate...
B@stard! ;)
Almost there!
Slow :)
Reactions: IPG and Tj 0785
If you want to free up any funds @<tuffty/> I'd take one of those climate controls for the double din set up if you plan on selling it.
You know the saying if you dont ask you don't get.
Lol... I had actually forgotten about those... Drop me a pm... I'll have a look for them and see what I can sort out..
I'll stick a classified in over the weekend for the other stuff :)
Reactions: hydro s3
