Audi S6 2001 (51) System Too Lean
pdpaxm
Hi,
I have just had my S6 serviced and also Cam Belt changed as done nearly 80k.
After this I keep getting the engine warning light come on, I plug in VAG-COM and it says:
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
I then reset the code, it runs for 2-7 days fine then this pops up again.
any ideas on what might be causing this?
Andy
Hi ok, I thought these cars were all setup etv via ECU is this not the case?
So the timing could be out if not done correctly when fitted the belt./
I would expect that to be an issue straight away really.
What fuel are you using in the car? Random question i know :blink:
I am using just standard unleaded, Shell sometimes and others just Tesco.
Only reason i ask is that we had issue's with a v6 golf a while ago that kept throwing up lambda codes. After changing pretty much every sensor we said he tried to use high octane stuff whenever he could, but his wife just used whatever. It was only when she did this that the light would come back on soon after.
I would try running it on some higher octane good quality fuel (shell v-power) and see if this has any effect. Its a lot cheaper than throwing new sensors at it left right and centre.
Just an idea :)
Andy
You should throw this up on rs246.com as well, to see what anyone over there says
Nice car by the way, any pics?
Mark
I had the same fault on my 2.7 S4. It was G70 air mass sensor.
If it was just one bank I would be looking for an air leak, as its both, the sensor would be top of my list. If you have vag com check MVB and drive down the road on full throttle in third. The flow rate will be low if its contaminated.
if like many other vag cars, suspect airflow sensor is under reading, so its only fueling for the airflow its seen come in...
i dont have figures off hand for airlfow to compare tho... but it should be in the high 200g/s region for 300+bhp
hopefully re-entering into the V8 side of life again shortly in an S6.
miss my S8 so badly.. gotta come back to audi v8
I
I
821
imported_kenichi5355
I
