My DIY Guide for Retro Fitting Foot well lights
Hi Guy's n Gal's,
Brought a set of these from RobinA3 a couple of weeks ago and just want to thank Robin for supply a top quality product, just like OEM.
Arrived save and sound within 2 days and installed with no probs.
If anyone is after puddle lihgts/footwell lights, RobinA3 is YOUR MAN!
Thanks again Robin.
Reactions: Dunedin and RobinA3
Picking up a S3 2007 plate this weekend, If they are compatible with this car, I may be interested in a set of front footwell lights :)
Any chance of them being white light?
would be greatful if you could drop me a PM with a quote
Will
Great write up Robin! Just noticed you have a G40 i used to have mk3 genisis! Do you know it the complete light led units from ebay will work and will be able to be coded etc?
Is it possible to get lighting under the Ac unit? Has anyone refitted the red light at the front inside door handles? My old a3 8l had a dimmer switch for the light pack..is this available for a 8P2
Would anyone know the part number for the pin for the white connector ? and or the name/type and manufacturer of the connector ?
Hi Robin
Are you still making the footwell lights? i would be interested in purchasing a set. Could you send me prices?
Hats off for the write up :)
For enquires about this kit and door warning / puddle kits please send me a pm.
Hi Robin...
i'm just looking for a bit of info on these and not an order....
Do you know when activating the footwell lights on the 08 pre-facelife 8p2 s3... Do you know if it gives you the menu on the display like the 58 8p3.... The reason why im asking... I put in all the cabling and even wired through a custom oem switch for the ch/lh light feature only to find out on the s3 that it was just a simple case of coding and they appeared on the menu....
if it didnt i'd just set the brightness high and also included a hidden resistor just so I have constant access to brightness levels without having to go through vcds all the time...? Thanks
Hi Guys. I have just received a second hand kit from a member on the forum and I cannot get it to work. My car is a 2009 s3 8P facelift (has the DRLs.) I have followed Robins guide to a T, making sure to plug the positive feed into the correct space on the cluster, and I have made a good earth. I have also enabled the footwell lights in VCDS. The lights will simply not come on though. The bulbs are LEDs, would that make any difference? Thanks guys.
This is doing my head in, making no sense at all. Even tried running a piece of wire directly from the terminal that the number 7 wire would be touching, but no dice. Do ALL the lights need to be plugged in and working for ANY of them to work? I tried touching the end of the number 7 terminal with a face testing screwdriver, and it lit up! But yet when I plug the connector back in, I get nothing.
Any help appreciated.
Have you checked the polarity on the led's? Some led's work whichever terminal the +ve is attached to, some don't. (Some change to red).
I have tested the LEDs outside the car using a spare battery, and there is only one way the units can connect when in the car. They also came plugged in from the previous owner so I dont think its a polarity issue. Thanks for replying though :icon_thumright:
Are the LEDs error free versions? Pre 11MY cars don't support standard oem led lights - you will need error free led bulbs.
To be honest I don't know. Its one of your looms, but I do not know about the LEDs. I tested them all outside the car last night, and only one of them worked! So I took them apart and to say they are a mess inside is an understatement. Total balls of a job they are, not sure where the previous owner got them. So tonight I am going to try plugging in a standard light with standard bulb to see if that's the issue.
If I only plug a bulb into the drivers side front connector, would it still light up, even if the other 3 connectors are not plugged in to anything?
Hey guys, Very interesting topic but does any body know how to use vcds to change the brightness setting on these?
Hello lads,
Fitted the footwell lights today, but seems my control Module or cecm is different, there's no red tab on mine.
Cars a 2010 s3 sport back.
Here's some pictures there not great though .
Cheers for any help in advance
Dan
20141224 184128
Hi guys, I fitted some footwell lights with normal LED's and they work.
Had to fit a single standard 501 bulb on the wiring. here are some pics
Reactions: VAG_Club001
Just finished doing this today,
Used led boards that come with the holders.
Does anyone know if its possible to have these come on all the time whilst driving but at a dimmer level using VCDS?
Can do this with wiring etc but if theres a easier way...
Hi Guys.
Going to be doing this in the near future, but dont have access to VCDS yet, so am thinking of wiring it to the interior light feed.
Where is a good place to pick the feed up ? im guessing the fuse for the interior light is constant +12v.
any tips welcome !
Just a side comment; you cannot use resistive dimming for LEDs, you have to use an LED dimmer.
Resistive dimmers reduce the voltages, so makes an tungsten bulb run continuously at a lower power (voltage). But the LED requires a minimum voltage to "strike", and is relatively insensitive to voltage above that minimum, so LED dimmers reduce the amount of time the bulb is alight, hence the amount of light they produce. (Simplified for clarity)
Note also if you have a error-free/canbus driver, you may provoke an error by reducing the load (higher resistance) or by providing a duplicate low brightness circuit.
Easy solution is to use a different bulb (like LED strips) which you can then use as you want (eg drive off a DRL control box, so only on when driving, and dimmed to half bright when side lights on) which then has no conflict with the normal puddle lights.
Hi, found this thread via the dutch audi forum, as many of us want the footwell lights u made i was wondering if u could send me a wire diagram so i could build same sort of loom. Sorry for the bad english ;) greetings
Yer I was gonna try that but could not find a wire coat hanger anywhere! Lol. Thanks for your help again mate. Also, how did you run the FW wiring for the rear lights?
Silky
just ordered a loom off the good man robin. A little advice if you can. I have a 59 plate black edition and i am assuming I have the same wiring as you with the 3 large plugs. I cannot tell as i have not removed the trim as yet. all cool with this, however after interrogating VCDS i have the same options as you to code the car, however I also have another option which is Byte 12. This gives the option to tick a box which says " footwell lights with terminal 58D active"
Any ideas? Leave well alone ?
Also once coded does it present the menu in the DIS to adjust the brightness and switch them on and off or will then simply just come on when i flick the headlights on ?
sorry to be a pain to everyone else but i might also do the rear footwells at a later date. Does anyone know how to remove the plastic sill plates so i can thread the wiring under here ?
yes, this is part of the ashtray removal kit. just done it at the weekend. all in all an hours job if you have the light
Can someone clarify for me : Footwell lights are not controllable from the DIS? I.e in terms of brightness, or when they come on and go off ?
I think it depends on what year of car. I have a 2012 car with factory lights which is controllable from the DIS. I just retrofitted the loom from Robin into the wife's 2010 (59 plate) and coded with VCDS and it opened the menu on the DIS the same as my 2012 car. I do have the later wiring in the car the same as Silky. Not sure about earlier cars.
I have MY2008 with retrofitted footwell lights and i can adjust the brightness through DIS(red). Advanced menu is enabled with VCDS though..
This afternoon i decided to retro fit some foot well lights, there are a few guides on the internet knocking around but i thought i'd do my own as i see there are many posts - including one from me - on how to do this retro fit.
From start to finish it took me about an hour to do, longest part was soldering the connectors onto the wiring.
First of all before i start the guide i would just like to mention that it was a bit of a mission getting hold of the correct electrical connectors but i have now got a number of them all therefore i am able to make wiring 'looms' for this retro fit to make it basically plug and play (apart from needing VAG-COM to turn the function on).
If anyone is interested then i am able to supply all the wiring, electrical connectors, plastic connectors and the actual lights as a 'kit'. The connectors have been soldered on and all you need to do is to connect everything up once its all in place, the length of the wires are all correct as well so no messing around for yourself.
If you are interested please pm me.
Right now for the guide.
First off you will NEED vag-com program the controller so that it knows there are footwell lights fitted.
To do this go to Group 09 and change Byte 00 Bit 2 to Position 1.
Now for the monkey work bit of the process.
Remove the 2 screws underneath the steering wheel trim, you'll need to get down and get your head underneath to see them.
Next remove the fuse box cover on the side of the dash, i used a screwdriver to lever it off.
Undo the screw at the top which holds on the steering wheel trim.
Now pull the trim away from the dash, it is clipped in at the top where it meets the dash, this needs a bit of force but make sure you pull it away from the dash towards the back of the car rather than levering it upwards as the clips may break.
Now unclip the electrical connectors from the headlight switch and remove the OBD plug at the bottom of the trim.
The trim panel can now be removed.
Now poke your head up in the foot well and look up for the bunch of electrical connectors, you'll see a red tab, push that and that will release the connectors.
Now use a torch and look for connector 'B'. It will be a black connector with only 4 or 5 wires going to it. Push the clip in on the connector and remove it from the main wiring block.
On the back of that black connector there are some numbers which indicates which pin is which, look for the hole number 7, it should be empty, this is the positive feed for the lights, on the side of the plug there is a bit of pink plastic, use a screwdriver to lever it away from the connector, this holds the pins in place, plug the connector of the loom into this hole, make sure it goes into No.7 hole because its virtually impossible to remove the wire from the plug once its in without the correct depinning tool.
Once you are happy with the connector, push the pink clip back into the connector and plug the connector back in to the main wiring block, remember to push the red tab back so it locks the connectors in place.
This is the feed sorted now, now you need to earth the wiring, i used a bolt behind the steering wheel, i undid the bolt and then tightened it back up with the earth wire trapped between the head of the bolt and the car.
Now its time for the passenger side.
Remove the side panel on the side of the dash as on the drivers side.
Undo all the screws holding on the glovebox, there are 2 underneath in the footwell, 4or 5 underneath the inside of the glovebox, one inside of the glove box at the back and one at the side of the glove box.
Let the glovebox drop down, you can remove the glovebox by disconnecting the connector one the glovebox but you will get a airbag fault warning on the dash afterwards as the connector feeds the airbag switch in the glovebox, this fault can be cleared using VAG COM. I removed the glove box completely for better access but it can kept on the floor to do the job but its more fiddly if you don't want to have to clear faults on the car.
Now you'll need to get the wiring to the passenger side footwell, i used a coat hanger and from the passenger side pushed it through to the drivers side just behind the stereo and taped the wire to the hanger and then pulled it through.
Once its pulled through you now need to push the connectors at the end of the wires into the plastic plug for the light.
Now connect the plug to the light.
Hopefully the light will now work assuming the vag com setting has been completed, if it doesn't work then you may need to put the ignition on and then turn it off again. If it still does not work then check the connections and earth points.
Once everything is working disconnect the lights and put back all the trim and glovebox etc.
Once its all done (making sure you haven't got any bolts left over) pull the connectors through the hole where the lights sit into the bottom of the trim, connect them up to the lights and push the lights into their location.
And there you have it, foot well lights.
I'll be doing the puddle lights and warning lights tomorrow so i will post a guide up on how to do that and if anyone is interested i could create a 'kit' up so it will be plug and play assuming its an easy job but looking at the wiring diagram it looks pretty easy.
OK I am completely new. I just bought a 2015 A3 2.0 and would love to put some lights on the footwell. Preferably red. So what is a VAG-COM to turn the function on?
Do you ship to U.S.A? And are your instructions also current for a 2015 model?
VAG-COM now known as VCDS is the software that is used to make all the changes to VAG cars. It runs along side a VCDS cable that is sold by Ross-Tech. Armed with this you can do anything that a main dealer can do. But DO NOT be temped to purchase a cloned cable with outdated software, these can either not work or potentially damage your car. you could possibly end up with a huge paperwight sitting outside your home. Also with original cables and registered software you'll get updates and support if needed. hope this helps.
tsw i am pretty sure i can sort you out a kit to suit your 2015 8v A3, drop me a PM.
