Post your eBay, Classified and For Sale links and wanted in here. Do not create a thread.
Would I be correct in saying you just replaced your grill? I have an aftermarket grill sitting in my hallway ready to fit to my 8P S Line. How much grief was it to do and is it doable on your own? Cheers.
You have to remove the bumper so to do that I jacked the car up and removed the front wheels as there’s not really enough space without. There’s then a few torx screws to undo the wheel arch liner which you then peel back in order to get to the bumper bolts inside the wheel arch, once that’s done there’s just some bolts under the bumper and on top where the bonnet release is. It’s not too difficult just fiddly but it’s doable on your own- just put something soft under the bumper inccasw it drops.
Reactions: Badger-a-s
Reactions: Paddyposh
Thanks very much, if it stops raining next weekend I will give it a go.
Do the fogs just unplug from the rear? Might fit some bright white Osrams while I'm at it.
Yeah there's a plug on either side which you undo then the fog lamp unscrews if I remember correctly.
Audi S3 8P 3 dr 2.0 Tfsi Milltek Turbo back Exhaust 76mm-70mm.
Exhaust needs no welding work etc, it is all ready to be bolted together & put onto the car.
The exhaust is 76mm from the downpipe all the way to the first resonator then 70mm back to the tips. Mid pipe was replaced for a 76mm decat pipe so the 70mm section starts from the first resonator backwards to provide maximum performance.
The original 70mm 100 cell sport cat & mid-pipe are still available & can be seen on the side of the exhaust in the pictures.
Exhaust has no cracks or holes etc, in good condition. I have various videos of the exhaust in use i,e of the car coming on boost so that you can hear it.
Please note:
1) Exhaust set up is currently decat (100 cell cat can be provided if wanted at an extra cost)
2) This is the resonated system, in my opinion, is way better than the non-res system as you can daily drive with no headache but sounds amazing on boost.
3) The exhaust is for the 3 door Audi s3 from 2007-2012 8P model.
4) Tips are the slashed GT80 style ones.
5) Collection only due to the size of the item from West London.
Looking for £620.00 or nearest offer.
Payment on the collection, please message for further details.
Pictures:
https://www.ebay.co.uk/itm/Audi-S3-8P-3-dr-2-0TFSI-Milltek-Turbo-back-Exhaust-76mm-70mm/323950459425
IMG 8014
Reactions: Bryant1998
RS4 OEM Fuel Injectors 079 906 036 C - FOR SALE
Used for only 15k miles on a stage 3 Audi S3. Genuine OEM RS4 injectors x4 set. They will need new seals & the metal crown clip that holds them in place to re-install. - https://www.akstuning.co.uk/genuine...kit.html?search_query=rs4+injector&results=59
Only replaced for RS3 injectors because MRC said they were maxing out limiting power but couldn't understand how all 4 OEM injectors only done 15k can all fail at the exact same time, these were bought new & are genuine. Turned out to be an old rs4 FPRV which was faulty causing the injectors to run at max so was then told they were fine after I had already put in a new set of rs3 ones. I would advise these get ultrasonically cleaned & tested for peace of mind. If the tests show any of the 4 injectors not working correctly as they should I will reimburse the full cost for all 4 that was paid for the injectors. I'm that confident that there is no issue with them.
Looking for £299.99 or nearest offer.
https://www.ebay.co.uk/itm/323923446917
Update: ARBs now sold. Intercooler and exhaust still available.
Audi A3 Paint code: LY5J (Liquid Blue) Complete Front Bumper required 2005-2008 style
Please let me know
Requiring armrest anyone has for cheap? A good onebeithout clips broken?
Sent from my SM-N970F using Tapatalk
Wanted: Milltek decat downpipe for 3 door S3 8P.
Let me know if anyone has one for sale :)
Thanks!
2 items for sale on ebay here are the numbers for the 2 items ( 202856519836 ) + ( 202856507973 ) i will happily take resonable offers from ASN members
My auction if anyone is interested for: Thule Kit 1417 - Audi A3 3-dr 2003-2012 & A3 Sportback 5-d 2004-2012
Thule Custom adapter kit (1417) now called (141417) for mounting a Thule roof rack system to select vehicles.
RRP £41.00
Fits:
A3 3-dr Hatchback (8P) with Normal Roof 2003 - 2012
A3 Sportback 5-dr Hatchback (8P) with Normal Roof 2004 - 2012
As with all Thule systems, you also need a RAPID SYSTEM specific to your car.
For more information check out the official Thule website:
https://www.thule.com/en-gb/roof-rack/fit-kits/kit-141417-_-141417
https://www.ebay.co.uk/itm/223848017841
S l1600
Hello all,
I have for sale 255mm brembo drilled rear brake discs come of a Audi a3 8p 2008 and brembo rear brake pads.
Also a pair of Screenshot 20200126 084722 Gumtree r
Screenshot 20200126 084251 Gumtree
h11 6500k led fog lights brand new.
Screenshot 20200126 084257 Gumtree
Is it good for the 2011 facelift s3?
Sent from my SM-N976B using Tapatalk
Yes , it will fit the facelift S3 too. You will need a new gasket for the turbo and Milltek recommend fitting an uprated dog bone insert as the pipe is much closer to the prop due to the increase in diameter.
Please note:
Pictures:
still available?
Thanks!
I have a Milltek 200 cell racecat in the classifieds if you'd consider one of those rather than a decat?
I currently have one for sale in the classifieds right now if you're still looking for one? Comes with the polybush insert mentioned by @nluk100 as well.
hi all im breaking a 2008 audi a3 1.6 petrol in black got nearly a full car there the passeger wing drivers wing and drivers door have gone still got both bumpers passenger door engine has 115000 on it good gear box aswell 4 alloys with tyres if you need anything just message me can post if need be just noticed the back passenger light case has a tiny crack in which will be reflected in price thanks
hi is this an S-line model or not ?
