Q7 Knocking sound at 1000rpm 2018 Sq7 tdi
tugglesf78
Evening all,
Got a bit of a head scratcher with my 2018 SQ7 TDI (auto, just shy of 100k). It's developed a knock at low revs, a sort of bump bump that I mostly notice pulling out at junctions. It's always at roughly 1000 to 1100rpm, and what's weird is it doesn't seem to care what gear I'm in or how fast I'm going. Same rev window every time. Gearbox is smooth, no shudder, and it's the same straight or on a turn. Seems to be coming from behind me, but I can't swear to that. It's slowly getting worse too.
Had it in with a garage for a few days and they couldn't find anything. They reckon it might be a suspension arm, but I'm not convinced. If it was an arm I'd expect it to clunk over bumps, not follow the revs.
Anyone had something similar on a 4.0 TDI Q7 or SQ7? Is the converter a known weak point on the 8 speed at this mileage? And can anyone recommend a decent VAG specialist in the north west, ideally one with proper Audi diagnostics?
Cheers in advance
I haven't got a q7 let alone an sq7 but I did a few searches for you and I've just published the found information below. Let's hope it helps you diagnose and sort it out.
An engine knock on the Audi 4.0 TDI V8 that occurs strictly at a specific harmonic window (around 1000 RPM) and disappears both below and above that range is usually related to fuel delivery/injection timing or component resonance, rather than terminal bottom-end mechanical damage (like rod knock, which typically worsens as RPMs increase). [1, 2, 3]
The most probable causes for this symptom on this specific engine architecture include:
1. Fuel Injector "Diesel Knock" (Most Likely)
    • The Issue: At 1000 RPM, the engine transitionally switches fuel maps or pilot injection phases. If one or more piezo injectors are slightly worn, clogged, or leaking, the fuel delivery delay changes. The fuel ignites abruptly all at once rather than burning smoothly, creating a sharp, metallic "clacking" or "knocking" sound.
    • Why it disappears: At higher RPMs, increased fuel rail pressure and altered injection timing windows mask the variance. [1, 2, 3, 4, 5]
2. Exhaust Downpipe or Flex Joint Resonance
    • The Issue: The 4.0 TDI generates immense low-end torque and specific vibrational frequencies. It is incredibly common for the internal braiding or structure of the exhaust downpipe flex joints to break down. [1]
    • Why it disappears: At exactly 1000 RPM, the engine hits a resonant frequency that causes the loose internal components or a heat shield to rattle aggressively against the chassis, mimicking a heavy engine knock. As soon as you pass that RPM, the vibration changes frequency and the noise vanishes. [1, 2]
3. Timing Chain Tensioner / Upper Chain Slack
    • The Issue: The complex chain setup at the back of the Audi V8 engine relies heavily on oil pressure. At a low RPM like 1000, the oil pump pressure is building but hasn't peaked. If a hydraulic tensioner is starting to bleed off or wear out, it can allow the upper timing chain to slap or whip against the plastic guides.
    • Why it disappears: Once the revs rise, the oil pressure spikes, fully extending the tensioner and taking up the slack. [1, 2, 3]
4. Dual-Mass Flywheel (DMF) Wear
    • The Issue: If your vehicle is equipped with a dual-mass flywheel, the internal dampening springs can fatigue over time. At 1000 RPM (just above standard idle), the engine produces high-torque power strokes that can cause the worn flywheel components to bottom out against each other, creating a distinct mechanical knock. [1, 2]
Recommended Next Steps for Diagnosis
    • Check Injector Deviation (VCDS / OBD11): Plug in a diagnostic tool and check the Mean Injection Quantity Deviation for all 8 cylinders. If you see one cylinder spiking significantly positive or negative compared to the others, you have found your faulty injector. [1]
    • The Chassis Test: While parked, have someone hold the engine precisely at 1000 RPM to duplicate the knock. Safely listen from outside the car—if the sound is louder underneath or near the front wheel wells rather than on top of the engine block, suspect the exhaust flex joints. [1, 2]
    • Oil Filter Inspection: To completely rule out terminal internal damage (rod bearings), check the engine oil level and inspect the oil filter during your next change. If you see shiny copper or silver metallic flakes, it is a bottom-end bearing issue; if it is clean, the cause is superficial or auxiliary. [1, 2]
To help narrow this down, does the knock happen when the engine is cold, hot, or both? Let me know if you are experiencing any rough idling or smoke from the exhaust. [1]
  • 1793703355918
    Speedway Motors
    How to Diagnose Lifter Tick vs Rod Knock | Troubleshooting Tips
    20 Oct 2026 — It might diminish or even temporarily disappear at higher rpm or under load, as the increased oil flow can fill the lifter and dam...
    1793703355937
  • 1793703355956
    audiengines.co.uk
    Audi Engine Knocking Noise Causes & How to Fix It
    Causes: Worn rod bearings and oil starvation, timing chain/tensioner wear, carbon build-up in TFSI direct-injection engines, fault...
    1793703355975
  • 1793703355995
    ATL Diesel
    Diesel Engine Knock: 7 Causes and How to Fix Each One
    Does it get worse under load? Normal diesel sound doesn't change much with throttle. Real knock often gets louder when you pull. D...
    1793703356013
