Diggumware
Audi A5 3.0 TDI Quattro - P214900, Cylinder Balance Issue, Limp Mode - Looking For Diagnostic Advice
Hi all,
I'm looking for some advice before I start replacing expensive components unnecessarily.
The vehicle is an Audi A5 3.0 TDI Quattro (V6 diesel).
Symptoms
The vehicle has been suffering with:
Work Already Carried Out
The vehicle was diagnosed by an independent Audi specialist who found a significant diesel leak from the injector leak-off/return assembly and associated seals.
The leak was severe enough to cause fuel to drip onto the exhaust, so the complete leak-off assembly, seals and associated parts were replaced.
The leak is now resolved.
What Happened After The Repair
After collecting the vehicle it initially ran smoothly for approximately 5 minutes.
The vehicle then:
The car then appeared to run normally again.
Additional Information
Because:
Questions
Thanks, Darren
Hi all,
Symptoms
- Rough idle
- Intermittent limp mode
- Flashing glow plug light
- Occasional stalling
- Fault code P214900
- Cylinder 4 = -3.90 mg/stroke
- Cylinder 6 = +4.79 mg/stroke
The vehicle then:
- Entered limp mode
- Displayed a flashing glow plug light
- Began running poorly
- Stalled several times
- Injectors have reportedly been swapped previously during diagnosis.
- The fault appeared to remain associated with the cylinder rather than following the injector.
- P214900 continues to be the recurring fault code.
- The idle correction values remain high even after the leak-off assembly repair.
- The correction values improve significantly off idle.
Because:
- The fault did not appear to move when injectors were swapped.
- The vehicle briefly improved after reseating connectors.
- P214900 relates to the injector circuit/group supply voltage.
- Injector wiring loom
- Injector connectors
- Wiring continuity
- ECU-to-injector wiring
- Injector 6 electrical issues
Questions
- Has anyone seen similar symptoms on the 3.0 TDI V6?
- Has anyone had P214900 caused by wiring or connector issues?
- Would you investigate the injector loom before replacing injectors?
- Are there any known weak points in the Bank 2 injector wiring on these engines?
- Does the fact that the correction values largely normalise around 2,000 rpm point anyone in a particular direction?
Thanks, Darren
