Driveshaft bolt question A3 8PA
Suffolk
Hi,
Sorry if this has already been covered however I'm going to change the o/s/f driveshaft, the bolt on the car is the 12 point 24mm smooth type but the one supplied with the new shaft is a 27mm 6 point hex.
Changing the shaft isnt a massive issue but I'm not sure about the difference in bolts, is it okay to use the 27mm bolt in the new shaft or are they incompatible, thought id ask the question before I pull the old shaft out.
many thanks in advance
J
It will be fine if the thread is the same, but good luck getting the torque as per elsawin, you'd have to use an elephant to reach that tightness & a fecking long thick bar & I have the so-called tools to do it lol
Reactions: Jamesholli
You're a star, thank you! I did the bearing a few weeks ago, your 100% on doing that bolt up its a right pain especially the 180º turn, I welded a 1/2" drive square to a long bit of box in the end to do it after snapping my breaker bar knuckle and landing on the floor lol - thank you again!
Reactions: NHN
At least they bar didn't ping up & whack your testis lol, seen that before, they didn't want kids anyway.
Update.. Before starting the job I thought I'd check the new shaft before stripping the old one out and found the inner drive flange was bent across one of the bolt holes... no lost knuckles for me today :)
Lol, that's called side stepping lol, very handy sometimes
