P2293 + P0341
Bens313
Oxfordshire
Hi All. New to the forum but ive had a look through and cant see anything recently that matches my issues. I recently bought a 2010 S3 CDLA engine 147k. Drove lovely on the way home and was giving it a decent push.
Ive had GTI's before so Cam follower was first on my list and i replaced that straight away. Brass shrader valve was rounded so had to hammer a 12mm on. Got it off eventually. No issues with internals, barely any wear on follower (At least 7k miles, replaced anyway) and lobe + pump look fine everything went back together okay. Since then i have been getting stuttering, stalling, Limp mode, EPC light coming and going and P0341 code. I changed the cam sensor and no change. I also changed the Crank sensor, seems to be a tad better but still same issues. Since doing the crank sensor im also getting P2293 codes.
My mechanic is convinced the timing is out due to chain slack/skipping and i can see why as the cam position and High pressure fuel pump codes are on two different areas of the cam saying something up. There is slight rattle from the cahin on some startups but id say about 0.5 of a second and fine when running.
Just to add a bit more information the codes show up very quickly so im sure that whatever issue this is wasnt present of the spirited drive home, i belive its new.
My questions are:
Do you you agree timing out could be the issue and its just a conincendence on the codes showing up after work has been done and not on the drive home?
Do you think hammering a 12mm ontro the brass could have damaged the internals of the pump? - Why cam code too though?
Do you think its worth taking the HPFP back off and checking for anything obvious? - Things seemed to go back together nicely and ive done this job a fair few times before.
Any other suggestions?
Thanks, im sure this wont be the first time im asking for help on here :friendly wink:
Ben.
Tbh if the car was fine on the way back & since the work it's had the issue, then it's unlikely to be a coincidence, 0.5 second chain noise isn't unheard of so I think that's a red herring, as it was doing this when you bought the car, id say you need to check your work & definitely the pump if it's had a fair whack of hammer.
Is it an OEM follower or good known brand, cam lobe show any wear, rounded of, although even if it does it's been fine in the drive back.
Thanks for the reply. Yeah im glad im not the only one who thinks it could be too much of a conincidence. Its a genuine cam folower sent out by AKS that went back in. Ill take the pump back off and have a poke around. I may try putting a used pump back on just to see if there is any differance if i can get one for cheap.
Still strange about the Cam sensor code but that could have been there the entire time (Didnt scan before doing follower) and not causing actual running issues.
Ah so you didn't scan the car before you bought it?
I was going to suggest try another pump, check connections to the pump, any damaged wires, bit of a stretch but check everything associated, check the follower is moving fine, no scoring to cam, follower channel etc.
No i didnt, silly, i know.
Will do. Ill take it all back off today and if i dont see anything obvious, ill order a second hand pump to put back on and see how that goes. Thanks for the help.
Update:
Started the car to move it into a better position to do the HPFP work and the chain is now really noisy and noise stays after startup. Perhaps it had not been driven hard before i bought it and me doing so has caused it to jump/slip. Either way it needs to be done regardless of other issues so will trailer it to the mechanic and update in here to see if it solves the issue.
At least it was pretty cheap to buy :frown new:
