Facelift Need help with 5F Faults
WGRacing
Hello everyone,
After changing the battery, I encountered numerous errors. I have managed to fix all of them except for module 5F.
I am currently getting 12 faults, all showing "B2005 00 [00001001] invalid data record" for:
1) 1585 - ASAM/ODX MUX
2) 1586 - speed shutoff thresholds
3) 1587 - language
4) 1588 - visible MMI system languages
5) 1589 - power management timer
6) 1590 - sound audio parameters
7) 1592 - DAB frequency tables
8) 1595 - audio management HMI constants
9) 1655 - sound announcement audio parameters (optional)
10) 1656 - sound cabriolet audio parameters (optional)
11) 1657 - sound configuration audio parameters (optional)
12) 1603 - speech signal enhancement - telephone/voice recognition signal processing (SSE)
Please see attached scan file.
Has anyone experienced this issue or know how to resolve these faults? Any advice or guidance would be greatly appreciated.
Thanks,
Wes
  • Scan-5F problems.txt
Looks like coding/adaptations might be incorrect, but also the dataset might be incorrect. Go to the dealer or a VAG garage with ODIS and a Geko account and ask if they can run SVM on the unit to restore the factory state.
Reactions: Poole
Thank you for the information.
I am heading to the dealership today. I heard from a former dealership employee that they may not perform the service if the car is out of warranty or if it has been modified, but I will see what they say.
I will follow up and send you an update after my visit.
Best regards,
Wes
If you have VCDS, OBD11 or ODIS Engineering, please make a full coding and adaptations backup of the whole car.
Do the same thing after the dealer ran SVM.
The dealer may indeed not do it if the car is modified (usually retrofits), because restoring original coding will cause more errors and may even make the car undrivable (e.g. the coding for the two way ABS sensors for PLA and ACC differ compared ot the regular sensors used for just cruise control on the ABS block). So they should not run SVM on all components, just 5F/infotainment.
Let see what will happen tomorrow. I let you know. Thank you.
I hate going to the dealers. They don't know what they are doing (sometimes). I asked service manager that I need to reflash ECU to factory setup. and I got the following description of the service to be done
Repair Services:
Electrical Systems Diagnosis
• CUSTOMER RECENTLY REPLACED HIS BATTERY, NEEDS BATTERY PROGRAMMED/REFLASHED.
I have Unitronic Stage 2 tune. I do not see that they changed ABS or Traction Control functionality. So it should be no problem.
I used that tune on the track successfully before I got problems after I changed battery.
After changing battery, I got a lot of faults. I fixed most of them by codding using data from previous scans. 5F long code is the same as it was before. Just cannot find the data 5F receive it from.
For example:
1587 - invalid data record
B2005 00 [00001001] - -
[Control module (data record download) - invalid data record for language]
I have to admit; I have not made a full coding and adaptations backup of the whole car.
I have experience, working and tuning aftermarket ECUs. But nut Factory one.
I have built and tuned my toy on the picture.
1792003602885
Invalid data record means dataset issue. Either run SVM online via ODIS to restore, or you need to flash the right one for your configuration.
But yeah, flashing ECU/TCU is something they won’t do because it’s a high risk of bricking. You either need to go to your tuner or flash it yourself if the files are available in the flashdaten archives/service42. There are websites and telegram bots which can send you the files for free or a fee. Then you need odis engineering and an interface such as the vnci6154a and flash it.
Hi.
I wanted to update you on my recent visit to the dealership.
They agreed to reflash everything back to the original setup. Although they warned me that there was a risk of burning the ECU, I decided to accept the risk and move forward.
They attempted the flashing process twice, but both times it failed and quit at 75%.
I suspect that something is wrong with the ECU. Lately when I was flashing my tune, it failed at about 75%, but the second time it finished successfully.
It is a possibility that the tuner put on some protection, so that it's very difficult to steal the tune. VAG does it too on selected ECUs (TPROT8/10 for example).
I've switched between Unitronic, Integrated Engineering (IE), and Stock tunes several times in the past and have never run into any issues before.
I got Alientech ECU tools. I will try to learn and understand ECU software modules and to program them (Winter project).
My friend has plenty of junk VWs I can practice on, and not to worry if something goes wrong.
Do you know what specific file(s) I should look for?
Need identification of 01 and 02 then. It’s in your autoscan from vcds. Hw/sw numbers, sw version and sometimes it has some more identification related stuff
Is it that?
Address 01: Engine (------DAZA) Labels:. 07K-907-309-V1.clb
Part No SW: 8V0 907 404 K HW: 07K 907 309 E
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 013 L HW: 0GC 927 711 H
I am starting to understand. I will look in my ECU backup to see what I have.
Thank you VERRY VERRY much.
_____________________________________________________________________________________________
Saturday,17,October,2026,16:43:25:56474
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 26.9.0.3 (x64) HEX-V2 CB: 0.4713.4
Data version: 20260828 DS378.0
www.Ross-Tech.com
VIN: WUABWGFF6LA901502 License Plate:
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
4B 52 5F 65 6C A5 BB BC CF D6 D7
VIN: WUABWGFF6LA901502 Mileage: 71643km-44516miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
39-Right Light -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
65-Tire Pressure -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Component: R5 2.5l TFSI X22 0001
Revision: 53X22000 CVN: AE68D587
Coding: 0A250032246600053620
Shop #: WSC 82976 802 690857
ASAM Dataset: EV_ECM25TFS0118V0907404K 001001
ROD: EV_ECM25TFS0118V0907404K.rod
VCID: 41DF5347810403A2A8E-8014
VINID: 9E54529D759619C44900114008000B13FC
No fault code found.
Readiness: 1110 0101
Component: GSG DQ500 H06 3104
Revision: 00H06V09 CVN: 34BFFD84
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021.rod
VCID: 3333098FCBB8A1322A2-8066
Address 5F: Information Electr. (J794) Labels:* 8V0-035-MIB-HGH2.clb
Part No SW: 8V1 035 880 F HW: 8V1 035 880 C
Component: MU-P-LNS-US 055 1363
Serial number: A702I0KB002633 Dataset Number: 8V2909545AB 0036
Coding: 017361020000000011220002041A00332F0028E4017001047E
Shop #: WSC 99999 999 2097151
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_VW37.rod
VCID: 3D272FB7FDFC6742CC6-8068
Data carrier:
Subsystem 1 - Part No SW: V03 959 802 DM HW: -----------
Component: NAR 2019/2020 --- 0072
Serial number: --------------------
Multimedia display unit 1:
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9K1Y0L0BU
Multimedia system control head:
Subsystem 3 - Part No SW: 8V0 919 614 BT HW: 8V0 919 614 BT
Component: ControlUnit_H H85 0858
Serial number: ALJAL113121800050442
Compact disc data bank:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 3013
13 Faults Found:
1585 - invalid data record
[Control module (data record download) - invalid data record for ASAM/ODX MUX]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:43
Voltage terminal 30: 14.3 V
1586 - invalid data record
[Control module (data record download) - invalid data record for speed shutoff thresholds]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:43
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:43
1588 - invalid data record
[Control module (data record download) - invalid data record for visible MMI system languages]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:43
1589 - invalid data record
[Control module (data record download) - invalid data record for power management timer]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:43
1590 - invalid data record
[Control module (data record download) - invalid data record for sound audio parameters]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:44
1592 - invalid data record
[Control module (data record download) - invalid data record for DAB frequency tables]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:43
1595 - invalid data record
[Control module (data record download) - invalid data record for audio management HMI constants]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:43
1655 - invalid data record
[Control module (data record download) - invalid data record for sound announcement audio parameters (optional)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:44
1656 - invalid data record
[Control module (data record download) - invalid data record for sound cabriolet audio parameters (optional)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:44
1657 - invalid data record
[Control module (data record download) - invalid data record for sound configuration audio parameters (optional)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:44
1603 - invalid data record
[Control module (data record download) - invalid data record for speech signal enhancement - telephone/voice recognition signal processing (SSE)]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:15:44
0020 - Tuner for Satellite Radio
B11CF 53 [00001001] - Deactivated
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 183
Mileage: 71643 km
Date: 2026.10.17
Time: 16:18:09
Voltage terminal 30: 14.6 V
Satellite radio tuner status-Satellite radio antenna status: electrically OK
Satellite radio tuner status-Channel selection for satellite radio: 0
Satellite radio tuner status-Audio Signal: Not available
Satellite radio tuner status-Antenna current: 0 mA
Satellite radio tuner status-Reception quality: Not available
Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
