Will I need to do cambelt soon if I buy this a3?
Jason1987
Well-Known Member
England
There’s a 2018 a3 with 52k miles for sale that I’m interested in. Though will that need a cambelt change soon? I’m reading mixed things online about that.
There is a lot of missing information about the car but in general a car at 52k should be fine to run another 50k before the cambelt (timing belt) needs to be replaced. Now this is all subject to previous maintenance and use. If you are really interested in the car, you could just have it done right after you've bought the car. Just make sure you knock the price of the replacement of the asking price. Than have it done somewhere else than where you've bought the car from. That's the only way for you to not worry about it.
It’s sold now lol. But looked very clean and in good condition. I just wasn’t sure if the dsg needs to have its oil changed and serviced around that mileage and the timing belt doing. It was £13,500.
DSG should have had it's oil and filter change at 40k at the max. So that should've been done... keep that in mind every 40k dsg needs fresh oil and a filter.
The timing belt on the EA213 engines has an interval of 210k km. Yes, that much. It isn't like an old school ordinary rubber belt that lasts 60k km. I replaced mine at 213k km, now reached 270k (so the new belt almost reached 60k km).
If it's an automatic, worry more about the crappy DQ200 transmission. Never flush it but do change the oil. Also get it tuned so it will slip less. The clutch won't last as long as the equivalently equipped MQ250 manual transmission, especially with the factory tune.
yeah i don't trust those numbers at all, fine if people do but i don't, simply because nowadays most engines are built to last about 5 years especially with that super thin 0w20 oil they use (and recommend) to meet emissions. Other than that, you are spot on the money regarding the DSG gearboxes.
The oil grade has nothing to do with the engine having a bad lifespan. The motor oil geek explained this in multiple videos. GM made this fatal mistake and tried to fix it with thicker oil, and guess what, it was not the fix for their engines.
The right oil, the right engine, the right time.
yeah and i don't agree with him, I've taken multiple engines apart and had to replace most of the moving parts due to excessive ware... after the bores have been honed and new parts installed switching to a thicker oil it doesn't happen again.... now this is first hand experience, so I don't agree with using flushing oil ( because that is the grade most engine flushing oils are 0w20) for daily use. Hell they used to use that also as a run in oil, that got replaced when you bought a new car off the assembly line.
But hey it has been debunked so it must have been another problem right?
I bought a 2018 A3 1.5 TFSI last year the dealer selling it had the cambelt changed, but I since found out that it was not needed as the factory belt is long life ? not sure how long though. The one I got had just done 35k was replaced with a gates kit which is OEM so hoping its all god for a while.
