S1 Turbo Actuator Replacement
hidnmine
Llandudno
Hi,
My 2017 S1 has an intermittent turbo actuator fault (VCDS 14846 / P2563 and 15202 / P00AF).
Has anyone on here replaced the actuator?
Can it be replaced and adjusted without removing the turbo?
How difficult is it to remove the turbo?
Any advice appreciated..
Thanks, Andy
Turbo removal is like this:
1785521111823
However, it does say the actuator can be removed without removing the turbo but the workshop manual says the catalyst needs to be removed - suspect if you have time to faff about a bit you could do it without, or undo it and move it slightly.
Actuators are available separately - lots of dealers tell people they have to buy a complete turbo unit. It'll need basic settings on something like VCDS afterwards.
Thanks Phazer.
I'm pretty sure it's the actuator at fault rather than the turbo, so good to know it can be replaced and adjusted in situ.
I've read the VCDS setup procedure. I'll test it before starting the work to make sure I'm clear on how.
If it's the right one, I've seen the actuator (06K145614G) on ebay..
Cheers,
Andy
Thanks Phazer.
Cheers,
Andy
That's good, also much cheaper!!
Part number is correct too
Well, what a fun task this has turned into.
As we all know, cars are designed by people who've never had oily hands (otherwise they'd make access easier).
Anyway, moving on..
Just to see the turbo, I've had to remove the subframe/steering rack (only had to cut off one seized steering ball joint).
Removed the front of the exhaust back to the sleeve joint. Had to disconnect the drive shaft to get it past.
I can see the actuator now, but still can't get to one of the two screws. I'll need to remove a couple of pipes next (one oil, one coolant, I think)
I'm going to replace the actuator, but am concerned that the setup procedure didn't seem to work when I tested it on the existing one.
I'll post a bit more as I go along
