Remap/boost issues
Stu_b7
Tiverton
Hi guys bit of an odd one here, so about a year and a half ago I had a Revo stage 2+ map installed with a SPS remote so I can go between stock and stage 2+ and I never really felt much difference if any between the 2.
So I have just a P3 boost gauge installed now and when I change between stock tune and what should be my stage 2+ tune nothing changes the psi readings are the same and 0-60 is the same.
I’m only getting max 12psi on stage 2+ setting so this can’t be right………. Right?
Sps remote? Aka someone just flashed a file remotely to your car? Did they send you switching hardware?
So the sps is a Revo device that stores the hardware and you can go switch between stock map your stage 2 map you can also have it so the car won’t start, I have tried them and they work but there is no difference between stock and stage 2+ on my p3 gauge and it doesn’t feel any different to drive
Than they didn't flash the oem map to it... simply said call them about it.
