Hi everyone. My 2017 Audi A3 S-Line,2.0 TDI lost its Central Electrics (09) Long Coding after a flat battery. It's a 30-byte module. Could anyone with a matching car please pull and share their factory long-coding string so I can recover mine?
Some backstory if its helpful - i had the changed the negative terminal as I was having trouble with the start stop function and an overnight flat battery - turns out I had just forgot to replace a fuse i pulled. After doing a scan it flagged up the U101400- control module not coded properly, everything worked as it should but i changed it back to the original negative terminal in hopes it would clear the code - it hasn't and it seems theres nothing I can do to clear it.
Any help or advise would be greatly appreciated
