11Mode exhaust valve controller
Jsimba
Berkshire
I know the ASR module has a lot of fans already. However I happened to come across this one from 11Mode which is half the price and the installation seems to only require fitting a small module to the exhaust flap controller under the car, so is a bit less invasive than the ASR.
Although worth mentioning this one only works via a remote rather than the cruise control stalk and is obviously going to be more visible given it's not tucked behind an internal panel like the ASR.
Still, might be something that a few people are interested in given how easy if seems to add/remove it.
Reactions: cheeseiznice
I fitted it. Works as described. 2 mins to fit. Very easy to remove. Just be aware you may get charged duty and VAT on import to the UK.
Reactions: Jsimba
Ah cool. Are you happy enough with it and the results?
Totally happy. It's not bonkers loud, just a bit more, just right. No drone. I turn it on at each startup, it defaults to stock on each power off, which works fine for me. No need to remove it at service, as it won't show up on ODIS as it's not activated.
I haven't got round to turning off the soundaktor yet, which can now be done with VCDS now it has an SFD solution.
Reactions: kayemill and Jsimba
So this doesn't void the warranty?
Take your view. If anything goes wrong, then expect a dealer to look to void the warranty by finding anything whatsoever that has been done to the car. It's a personal risk analysis.
I have one fitted on mine. Very happy with it.
Has a simple 2 button controller, Valves Open or OEM. I liked this more than some others on the market that have an additional Force Valves Closed mode which could in theory cause damage.
Super easy install- unlike others that require you to remove trim panels around the dash
Looks like they have an updated version which now has a memory mode to retain your last setting.
You're correct - looks like anything being shipped from mid-Jubne onwards gets the memory function.
And I agree about the install too, which is what caught my eye - it would be nice not having to remove door pillar trims to fit it!
I think I'll give it a go and see how I get on
