Hi, all
Any help, advice, ideas, expert contacts on this issue would be massively appreciated.
Just after xmas I purchased a 2007 2.0 petrol special edition avant with a manual gearbox with 135k on the clock.
I've probably only done around 1500 miles since then, but on at least ten occasions it has absolutely refused to go into 1st gear (when the car is stationary) & I've had to pull away in 2nd, then it'll be fine again.
Now, this is not ideal & quite frustrating but I was kind of hoping that it might be clutch related, as I have no record of it ever having been replaced, despite having an entire folder of history from it's extremely thorough previous owner of 16 years.
Fast forward to today, when I have the front of the car on axle stands (rear wheels on the floor) because I'm stripping the front brakes off for a full rebuild & I put the car into gear to stop the hubs turning. Well, the O/S hub locked up as you would expect, but when I was working on the N/S, the hub was spinning freely. Not good I thought. Put the car back into neutral, started her up & selected 1st & released the clutch, the O/S hub had drive & was spinning as you would expect, but nothing on the N/S. Same with 2nd gear. 3rd Gear it did start to rotate slightly, but I didn't want to give it any throttle for fear of it coming off the axle stands from the rear wheels driving it forward. It was also making a bit of a weird straining noise because it wanted to drive, but had the handbrake on.
So now I'm thinking that something has physically broken inside the gearbox or another part of the drive system that is causing the no drive issue with the N/S front wheel & is also possibly the cause of not being able to select 1st gear sometimes. I have no idea if this is even possible? It would also explain why the car feels weird when going round a round about or turning at slow speeds, because only one front wheel is being driven! Even turning & pulling off the driveway feels odd, which has always baffled me.
Does anybody have more knowledge than me on the gearbox components or if theres anything within the quattro system that could be broken & explain this fault? Perhaps it's a common issue that I don't know about?
Either way, it seems like it needs looking at by a specialist. Can anybody recommend one in the Oxfordshire area?
I'm not sure what more I can add, but happy to supply more info if I can, if required.
Thanks very much
Thanks very much
