New RS 5 Tech Explained: Quattro with Dynamic Torque Control
A260651 medium
Audi has gone properly deep with the new RS 5, and the headline feature isn’t just the hybrid power - it’s what’s happening at the rear axle.
Meet quattro with Dynamic Torque Control - Audi’s latest evolution of torque vectoring, and a genuine world-first system that could redefine how RS cars handle.
What Is It, In Simple Terms?​
At its core, this is a next-gen torque vectoring system that can actively shift power between the rear wheels - not just under acceleration, but all the time.
  • On throttle
  • Off throttle
  • Even under braking
That’s the big difference. Unlike older systems (or clutch-based torque splitters), this one doesn’t rely on engine load. It’s always working, constantly adjusting, and reacting in just 15 milliseconds - quicker than you can blink.
What’s Actually New?​
Audi hasn’t just tweaked an existing setup - they’ve built a completely new rear transaxle for the RS 5.
Key bits:
  • A 400V electric motor (8 kW / 40 Nm) acting as a high-speed actuator
  • Overdrive gears
  • A reworked rear differential
This setup allows the car to actively push torque left or right across the rear axle, depending on what the car is doing - and what you’re asking it to do.
What Does It Do on the Road?​
This is where it gets interesting.
Turning in​
As you brake and turn into a corner, the system helps the car rotate cleanly - reducing that traditional Audi understeer.
Mid-corner​
It balances the car by adjusting torque between the rear wheels, keeping things stable and predictable.
Corner exit​
As you get back on the throttle, it can send more power to the outside rear wheel, helping you get on the power earlier and harder. Audi claims it can shift up to 2,000 Nm of torque difference across the rear axle - which is a serious amount of influence over how the car behaves.
Understeer? Oversteer? It Manages Both​
  • If the car starts to push wide (understeer) → more torque goes to the outside rear wheel
  • If it starts to step out (oversteer) → torque is redirected to stabilise the car
All happening instantly, without you really noticing - just feeling a car that’s more planted, more agile, and easier to place.
What Does It Feel Like?​
According to Audi, the goal is simple:
  • More direct response
  • More predictable handling
  • More confidence at the limit
And importantly - it’s not just about outright pace. It’s about making the car feel more natural and more controllable, whether you’re pushing hard or just enjoying a fast road.
Drive modes will still play a big part too:
  • From neutral and stable
  • To more rear-biased and playful
So yes - expect some sideways conversations on here…
How It Works with Everything Else​
This system doesn’t work in isolation. It’s tied into:
  • Adaptive suspension (twin-valve dampers)
  • Brake torque vectoring (mainly front axle)
  • Electronic diff systems
  • Central control unit (HCP1)
Everything talks to everything - constantly adjusting based on:
  • Steering input
  • Road conditions
  • Driver intent
It even interprets how you turn the wheel - whether you’re correcting a slide or attacking a corner.
Why It Matters​
This isn’t just another incremental upgrade. It’s a shift in how Audi approaches handling:
  • Less reliance on front-end grip
  • More active rear involvement
  • More adjustability without sacrificing stability
In short - less “safe understeer Audi”, more “properly adjustable RS car.”
Final Thought
Audi says this system makes the RS 5 feel more playful, more precise, and more accessible - which is a big claim.
The real question for us is: can we have a go?
Reactions: Sandra and Jsimba
Audi A2 e-tron Set to Become the Brand's Most Efficient Car Ever
  • 63
Audi has revealed more details about the upcoming A2 e-tron, claiming it will become the most efficient production Audi ever built.
According to preliminary WLTP figures, the new...
Audi Brings Nuvolari Supercar and Motorsport Legends to Goodwood Festival of Speed
  • 302
Audi is bringing both its future and its past to this year's Goodwood Festival of Speed, with the all-new Audi Nuvolari making its dynamic debut on the famous Hillclimb alongside a...
Dollner Doubles Down On Audi's 2030 Challenger F1 Target
  • 331
It has been all change once again in the sport of Formula 1, from driver Team changes, the end...
Third-Generation Audi Q7 Revealed: More Space, More Tech and More quattro Capability
  • 348
Audi has revealed the latest chapter in one of its most important SUV stories with the arrival of the third-generation Q7.
Since its introduction in 2005, the Q7 has become Audi’s...
Audi Nuvolari: A New 1,001 PS Hybrid Supercar Era Begins
  • 592
  • 1
Audi has revealed its most extreme road car yet — the Audi Nuvolari, a limited-production hybrid supercar created to showcase the future of performance from the four rings.
With just 499...
