Heater matrix keeps blocking :(
Pez
I've got a 65 plate S3 and keep having issues with the heater matrix blocking up.
First happened a couple years ago and I was told the silica bead bag in the coolant had burst and blocked it so had to replace it.
11 months later it blocked again with some kind of sludge. I was assured it was a different issue to the beads, just had the same result. New matrix.
Another year and the heat is failing again. It went in and they replaced the coolant shut off valve (error codes indicated it was failing). Didn't help and I was told the matrix is getting blocked again.
This time I was told the whole system is coated on the inside with some weird sludge stuff (photos below) and as its comes off the inside of the pipes it gets to the matrix and slowly blocks it.
All they can suggest is to keep periodically going in to get it flushed out (which I'm not being charged for). I've haven't gone for a 4th matrix yet...
Any ideas what it is, and how to deal with it?
PXL 20260330 165432910
PXL 20260330 165442040
The Audi A3 heater matrix most commonly associated with preventing silica bag issues is the copper and brass design, which features wider water tubes that allow small particles to flow freely without blocking. This contrasts with the original equipment and many cheap replacements, which use aluminium with very narrow water tubes that block up quickly if silica gel from a burst bag enters the system.
While the silica bag in the coolant header tank is the root cause of many blockages on the MQB platform (A3 8V, Golf 7, Leon, Octavia), replacing the matrix alone does not stop the silica from degrading. Forum discussions indicate that removing the silica bag entirely is a common preventative measure, but this requires changing the coolant every couple of years to maintain system protection, as the silica was originally added to extend the life of G13 coolant.
Key Recommendations​
  • Heater Matrix Type: Choose a copper and brass heater matrix (e.g., from specialized suppliers like The Car Heater Shop) as it is less prone to clogging from debris than standard aluminium units.
  • Coolant Management: If the silica bag is removed, switch to G12 Evo (ready-mixed, factory fill from 2017) and change the coolant every 5 years or every couple of years depending on the maintenance strategy chosen.
  • Alternative Fix: Replace the entire coolant expansion tank with a new unit that does not contain a silica bag, ensuring the cooling system is fully flushed to remove any existing silica residue before installation.
Reactions: Pez
Appreciate the reply, very helpful. I'll print it and take it to the garage.
Even if they know it, it'll give me peace of mind
I have had this problem twice on 2 different 8vs both tdi and the one I have now had to have another one after 4 moths due to leaking, I have checked and removed silica bag which intact so could not be the issue. I have heard that grit from when the block is cast can be the issue not sure if anyone else has heard this?
