Help/advice with start and cut out problem
markspark
Some help/advice please 2011 A3 2.0tdi CFFB. When the engine temp is cold the car will start and drive fine with no issues and will keep going all day if required but once engine has warmed up and is switched off upon restart it just starts then cuts out until the engine has cooled or just keep trying and it will start eventually and then will run perfectly until engine is turned off again.
I have scanned with vcds but there are no faults showing
I have tried the spare key with no difference at all
Fuel delivery appears to be good
With the no fault codes stored I’m at a loss with where to look first
T.I.A
Same issue had it was the crankshaft sensor .Replaced it with oem one from donor car .The car would not star with aftermarket ones i tried Bosch and Valeo
