S4 TFSI or S4 TDI?
me77or
South Manchester / Cheshire
Hi folks
The time has come to part with my S3 8P, after 170000 miles. Sad times, but I'm looking forward to replacing it with an S4, but which is would be your choice?
The TFSI would be my first choice, but the rocker arm issue puts me off. The TDI doesn't suffer from this issue (does it?) but its a diesel and has those horrible fake exhausts. And they are more expensive.
I'm looking at 2018 - 2020 cars, with a max budget of £27000. What would your choice be?
I'm also keen to hear people's input on this one as im toying with the idea of upgrading my current A4 B9 2.0 TDI Avant for something with an S badge on.
Depends what you want or indeed what you watch? If you watch the VAG Technik videos on YouTube you’d never buy a performance car again. I do think that regular servicing is key though. Most of these cars cars have been ragged, and further down the line the new owner picks up the bill. Tomas and Miroslav know their stuff, so watch their back catalogue and make up your own mind.
The S4 TDI does interest me. Why? I’m driving a 3 litre (272PS) Quattro and it’s the best car I’ve owned, and probably my last diesel. It’s Euro 6 standard, however to achieve that, Audi have thrown in DPF, AdBlue, EGR and cats. With all diesels you’ll ultimately get emissions issues down the line. Also, B9 platform has suffered from more than its fair share of AdBlue issues, usually tank sender, heater or pump, but as the whole thing is integral unit, it’s expensive to replace. I’ve started using Forte Anti-Crystal on every AdBlue top up, and before a fuel filter change Forte diesel additive.
Enough of the down sides. Positives on TDI is low end torque. It will literally cruise all day in efficiency mode, quick tap of the Tiptronic into sport mode and I’ve 600Nm of torque on tap. TDI S4 gives you 700Nm of torque which is more than enough power.
Do your research though in term of standard kit. Audi are as tight as a gnat’s chuff with equipment levels, so make sure you have everything you want. Retrofitting is expensive.
Volkswizard (YouTube) had S4 TDI as daily driver. I don’t particularly like the channel, but it’s worth a watch.
Finally, whatever you decide, get yourself a full copy of VCDS. You don’t need to be a mechanic to use it. These cars are sensor heavy, so it pays to know what’s going on. You can purchase from Gendan UK.
Test drive both if you get a chance and be prepared to travel for the right car. Anything on a long service regime, walk away. I’d be looking at oil changes every 5-8k miles.
Reactions: JohnNW
Hi folks
We have a 2020 S4 Avant TDi paid about £28k for it a year ago. No one cares that one side of the exhausts are fake because 99% of folks simply don’t know so don’t let that put you off - drive the TDi against the petrol and you’ll be blown away by the power and performance. We use ours across Europe where it’s the perfect GT car with amazing fuel economy and power when you need it.
All good valid points. All the diesels have poor sensors to identify issues compared to the petrol versions and yea you’re probably correct nothing goes wrong with the engine itself it’s usually the downstream ‘emission’ stuff that requires attention however as long as the TDi car has had proper servicing and all consumables plus wear and tear sorted it should be fine. As usual we do regular oil and filter changes every 6k maximum and find a good Audi specialist who can look after the car with you.
One final thing Audi updated the ECU/TCU and MMI software around 2022/23. I got Audi to do the update and has to push them hard - it changed the MMI interface for the better and fixed some of the connectivity problems like WiFi wasn’t working and over the air map update also wasn’t working. It also fixed any turbo lag and made the gear changes quicker. Finally it changed the sensitivity of the brake pedal for the better so it wasn’t so loaded at the top of the pedal.
One last thing get a warranty with the car just in case anything plays up with the emission side as it can be a little pricey to fix but a good warranty should cover it. Ours came with Warrantywise Platinum.
The Mythos Black car that Andrew on Volkswizard owned has been my partners car since April 2025 and she loves it. She also drives a 911 Carrera 4S.
Reactions: spartacus68
