DSG N or D at traffic lights?
Rommel
Sandhurst Berks
2018 A3 DSG owners manual says do not let it creep in drive as it can wear clutch pack, but what about at traffic lights should it be left in drive with foot on brake or put into neutral? revs drop with foot on brake so is this disengaging the clutch packk??????
TIA.
Reactions: northpole
It acts like any automatic when putting on the brake... it's still engaged but allows slippage, best to put it in N.
That would only be the case with wet DSG transmissions (DQ250, DQ381).
The DQ200 would simply disengage and basically be in neutral, as it's a dry clutch system (1.6TDI and smaller TFSI engines).
Reactions: northpole and Genespleen
Perhaps o/t but I used to roll up to lights etc in the RS3 in neutral, blip the throttle a few times then just brake to a stop in N.
TX.
Probably good practice, having done 146k miles on the original engine and DSG transmission (both serviced at all intervals), I still don't have an issue while coming to a stop in Drive, leaving it on brake at the lights etc and then driving off. Clutch etc are still fine.
The bigger issue I see is leaving it on brake after heavy or moderate stops where the heat can potentially warp the discs over time, so I let it creep forward to help with that
Reactions: Rommel
warped disks jup been there with a few automatic cars from different brands... all coming from people riding the brakes instead of putting it in N after pushing the car hard... evidence was both warped disks and glazed over brakepads... especially found on Mercs. Not a problem as disks for lower spec models are cheap, but when it's a big engined one the disks and pads are seriously expensive when going the OEM route ( and in some cases those are your only option) .
Now back to being a good automtic driver... yes when coming to a stop for a traffic light one should put it in N.... most people don't. I don't do it when i run up to a light that has been on red for a while because i now it'll soon jump to green, but if it just jumps to red and i know it's a light that stays red for longer than 1 minute i put it in N and put on the handbrake instead of ridimg the brakes....
Up to the owner i guess... and their knowledge of the trafficlights timing around their area.
