Fitted Eventuri Carbon Intake on my 8.5Y RS3
Iby_d
Hey guys,
Just wanted to share my experience fitting the Eventuri Carbon Intake on my 8.5Y RS3 (2025) — and honestly, it’s been one of the best upgrades I’ve done so far.
The Fitment
The Eventuri kit comes really well packaged, all carbon parts were perfect — zero defects in the weave or finish.
Installation was relatively straightforward:
  1. Removed stock airboxes — requires loosening a few clamps and removing the stock air box bracket.
  2. Fitted Eventuri heatshield.
  3. Slid in the carbon tubes and filters — you need to leave all claps loose until you find the sweet spot for everything to sit and then tighten everything up.
  4. Connected everything back up — no modification needed, pretty much plug-and-play.
Took me about 2/2.5 hours at a relaxed pace, and having a second set of hands helps when seating the tubes.
Sound / Intake Noise
This is definitely the biggest daily-driver noticeable change:
Cold start & revs: noticeably deeper, more aggressive intake howl
Blip / throttle on/off: stronger whoosh, especially on clutch-downshifts
Not obnoxious, but you can hear it from the cabin — and it makes you smile every time.
Looks / Quality
Build quality is excellent — carbon finish, fitment precision, and the silicone couplers are top notch.
Under the bonnet it just looks cleaner and more purposeful than the stock setup.
PS. Tuning box and OPF emulator up next.
Reactions: RS3nz, Kevmoz, northpole and 2 others
