Android Auto not connecting wirelessly
Rambo91
Member
Sweden
I have Android Auto on my S3 8V 2020, but it only seems to connect through USB. I have Android 13 on my phone so that shouldn't be an issue?
Get yourself one of these and you'll be set: https://amzn.eu/d/e6pM1HM
I have the first model they made and it works well. You can also get any cheaper alternatives but I haven't used the cheaper ones so unsure on reliability. I went with the AAWireless brand due to the extra settings you get like being able to make it turn off after x seconds so it doesn't keep your phone connected when leaving the car.
Reactions: Rambo91
Seems like you still need to plug in your phone to the adapter?
My brother in law showed me this one by Ottocast, but I thought I'd ask on the forum to see if it was really the case that 8V doesn't support wireless CarPlay
Amazon product
View: https://www.amazon.co.uk/Ottocast-Wireless-CarPlay-Bluetooth-Reconnect/dp/B0G48R17RV/ref=pd_rhf_se_s_pd_sbs_rvi_d_sccl_1_2/522-8478234-7458907?pd_rd_w=ooqVf&content-id=amzn1.sym.0f49b2d0-6326-4aee-911a-a977f4ca7c12&pf_rd_p=0f49b2d0-6326-4aee-911a-a977f4ca7c12&pf_rd_r=WB39B1XJ1J4WHR0J710D&pd_rd_wg=WEZg8&pd_rd_r=d30bbe80-c4ee-4995-8708-0b1f480be36d&pd_rd_i=B0G48R17RV&psc=1
Nope, you plug the dongle/device into one of your USB ports (mine are in the arm rest) then your phone will connect to that via WiFi and to your car via Bluetooth (both are required for android auto).
Carplay is for iphones / apple devices, some dongles provide both AA and carplay, I have an Android device so haven't needed to worry about carplay.
Just ordered this! :D
Reactions: ChickenDipper
Nice, far easier than having to plug in! I went a step further and got myself a wireless charger that is mounted using a cupholder mount just under my A/C controls, AA draws some power and this is such an easy setup :p
I gave the Ottocast Mini Pico a try, and unfortunately it keeps dropping after like 5-10 mins. I think the longest it lasted was like 15 mins. Anyone experience anything similar?
MHS2 and MHI2 systems do not support wireless android auto or wireless carplay.
Your best option is a €10 wireless adapter you can get from AliExpress (they're all good as the screen res is 800x480, so the data transfer isn't bottlenecking the adapter).
Other more expensive options exist (e.g. Aa wireless, but it doesn't support wireless carplay like the AliExpress adapters do). Ottocast is also available for relatively cheap, around €30-40.
I wrote earlier that I gave the ottocast Mini Pico a try in case you missed that. It kept dropping and customer service is really annoying. What would make the AliExpress adapters work since they're even cheaper. Do you have one and have tried it yourself? If data transfer isn't bottlenecking the adapter because of the smaller screen res, why does my Ottocast keep dropping?
I have 2 of the AliExpress dongles (different models) and never experienced lag or signal drop. I know that it depends on the area you drive through as well.
I set the WiFi setting to use a 5GHz channel.
I can thoroughly recommend an AAWireless dongle for this too. I had a 2019 8V RS3 and it worked a treat, you just leave the dongle plugged into the USB socket and it'll connect to your phone wirelessly on startup to display Android Auto on the screen. Hope that helps
Thanks for this. Isn't the connection via Bluetooth though? As far as I'm aware the AA adapter dongle that I have is supposed to be a plug and play solution via Bluetooth, so there has been no mention that the car needs to provide WiFi.
For clarity, this is the dongle that I have: https://www.ottocast.com/en-se/products/ottocast-mini-pico-wireless-carplay-android-auto-adapter
I think they probably do the same thing, just from different brands. The car doesn't need wifi for AAwireless to work
