Just fitted the ASR, well, the Alarm man did being as he was fitting my Immobilisor/tracker when the UPS van pulled up outside, all went in OK ish but there is a connection under the steering column on I suspect the steering wheel controller and the unit itself fits in the LH footwell.
The way he/we fitted it the twisted pair (can bus) lead was too short so needed an extension, no big deal and probably easier to fit with just a wire to pass from right to left instead of trying to get a pair of 40mm x 10mm male and female plugs through under the dash. (I have given ASR feedback and suggestions as they have probably never fitted one to a RH drive car)
All works fine, lovely to see the SS switch illuminate and a little graphic with Lane Assist Off appear, nice thing about the Lane assist is 'IF' I ever decided to use it I can switch it on with the stalk and the next ignition 'ON' it will revert ot off as it has to be set in the MMI for the memory to work, exhaust sounds nice as well.....Happy Days
