Mk2 TT Roadster Header Trim
elan2s
The piece of plastic at the front of the roof on my roadster (the part that runs across the width of the car and is attached to the and covers the emergency release/locking mechanism) has come loose in the centre section (rear view mirror area). Can't see obviously how it is fixed. Found two very small plastic pins when feeling around incase a screw had fallen out. Any help gratefully appreciated
I can't recall but usually on cabs they're held in place by spring clips bud & I've found the same on various chassis when fitting systems & it's not easy to dislodge these so what's the story.
Thanks. Not sure what has happened. Got in the car this morning having not driven it for a bout a week and noticed the trim had dropped slightly. Will need to do some more investigation as to why
Had a closer look and it appears there is a panel clip to the rear of the centre section that is missing. Not sure what happened as there is no sign of the missing clip. New clip ordered so will hopefully have it dorted tomorrow
New clip has fixed it!
