Hello all,
I got myself into a bit of a mess. I decided to rebuild my 2.0T (BUL) engine.
Long story short, the engine block and cylinder head ended up being machined. It wasn't my idea at all, but I was advised to skim the head as well as the top of the block, just to make the head sit better. The engine's original problem didn't have anything to do with the gasket but I accepted doing it just for the sake of doing the job only once the proper way. I wanted to avoid building and rebuilding just because of the head not sitting correctly. The problem now is the following. I've just fitted the pistons back in, and the clearance is absolutely non existent. Moreover, there is a protrusion that can be seen and felt (probably about 0.2mm, I haven't measured yet). The workshop says they took 0.006in off the cylinder block, which equals to roughly 0.15mm. I didn't take the measure before giving it to the workshop, but given the state everything was in, the the bearings, rods, pistons, etc being genuine, I would bet all my money on the engine having never being opened. In the end, something doesn't add up. Does anyone know with any degree of certainty what the clearance is from the factory between the top of the piston and the top of the engine block?
Thanks to anyone reading !
