Unable to open car due to low battery - heres the answer
superb
Reading
Recently left my car parked up and the battery has become completely flat. Using the key in the door doesn’t unlock the vehicle. I used to have a central locking leak to I’m assuming the system has lost all vacuum - I didn’t think this would stop manual opening of the door. The boot lock seems to be broken, also.
My current plan is to take the wheel lining out and see if there’s a way to open the bonnet and recharge the battery. Does anyone know another way to enter without breaking any glass?
The car should open manually as I have opened mine with the battery disconnected when working on it have you tried the key in both directions?
Sent from my SM-S908B using Tapatalk
Aye. Tried turning the key in both directions but nothing happens - I’ve opened the car before with low battery and key and it’s always worked.
Reactions: MPH
Strange one I've just opened the bonnet on mine to check for any access you maybe able to go through the plenium chamber as the gap looks like you may be able to get a coat hanger of similar on it.
Thanks mate - appreciate it. Can you see any access to the bonnet release cable?
Reactions: MPH
Maybe possibly through the grill but would be a struggle one of the pics show a possibly entry point rear shot of catch.
****** hell - no easy feat then. Thanks for the phots
Reactions: MPH
Use the key to unlock the boot and climb through
Sent from my SM-S926B using Tapatalk
For anyone with the same problem, here’s how I fixed it.
Problem: the locking system is electromagnetically actuated. My battery read 2.4v which was insufficient to un-deadbolt the doors.
Solution: Jack car up, remove NS wheel arch lining. Remove plastic trays under engine. Forward and up of the gearbox is the starter motor; at the top of the start motor there is a black plastic cap - remove this cap by pulling it off towards you. A (possibly) m10 post will become visible with a 13mm nut. Attach a small crocodile clip to this post. Attach a jump lead to the chassis (make sure to test for ground). Attach starter motor clip to positive of spare battery, attach negative to spare battery. Car will now have sufficient voltage to unlock.
Required:
Key
Jack
Stand
Torx set
Crocodile clip and jump leads
Way of providing 12v
Reactions: voorhees and MPH
I think given that the 8L is a legacy Audi I will add this to the stickies :salute:
Reactions: superb, Sandra and MPH
Same thing happened again - after 3 weeks of not being moved, with a brand new battery.
Followed my above process and was in the car within 15 minutes. My next job (once the battery is recharged) is to identify the parasitic drain on the system. Aftermarket head unit or alarm siren will be the first things I’ll investigate.
Reactions: MPH
My car has been immobilized the last year or so. The battery was serving only as a decorative piece in the engine bay. I could access the car either by the driver's door or by the boot door. Both door locks were a bit stiff, but nothing too serious. Are your door locks turning relatively easy with the key in, or are they sticky?
I also had a MK3 Golf which also had vacuum locking system. In a similar situation with yours, I used the key to hold it in the unlock position (forcing it to stay unlocked) while with my other hand I pulled the door handle and gained access to the car. This was caused by a massive leak in the vacuum lines of the locking system.
Having done the process a few times now, I think there is a combination of faults which are relatively common across MK4 platforms.
With >12v on the battery, my key doesn’t manually unlock the door, it will only lock. Additionally, the boot is notorious for leaking which I believe has damaged by rear wiper motor and keyway - I can’t insert my key the entire way.
The only way is 12v and remote central locking for me. I need to completely redo the central locking but it’s far down the list of jobs at the moment.
