Smart Alternator (reduced charging)?
Rambo91
Member
Sweden
For the first time today I heard about the smart alternator feature and was frankly quite shocked that this existed as I was discussing battery lifetime with a colleague. Classic setup is that the higher revs you have the quicker your battery charges, but here depending on driving conditions, battery might not barely be charging at all!!
Anyone know of a way to remove the "Smart" function so that it runs like a normal alternator?
The smart alternator actually extends the battery life by quite some time... a battery that already reached max charging capacity, will deteriorat quicker if it still gets pushed to take a high charge current.
I'd leave it be if I was you.
Fair point. However a colleague of mine had to change his battery after 5 years (which triggered this discussion), and that's not a lot. It would explain why batteries have to be changed more often on modern cars (around 2019 upwards). Scenario: You drive one hour on a flat surface with partial throttle, AC and other electrical equipment on, the battery will be affected.
I'll leave it be as you suggested anyway, as I learnt that when it charges, it sends a higher voltage (like an overcharge) which is fair enough, and also you get a bit more power :p
The battery lasted 5 years before it needed a deep charger or replacement? Not bad for a stop/start equipped car.... do you actually realise how much stress is put on those batteries? This is the reason they have a smart alternator.
If you want those batteries to last longer, make a habit of using a trickle charger when the car isn't used overnight at the weekends. ;)
That's contradicting what you said in the first post though: If the battery deteriorates quicker with a standard alternator, how come they last much longer than ones with a smart alternator?
For example a car from 2017 compared to 2021 has nearly identical electrics.
I do have a small trickle charger, but I live in a flat with a parking space in a garage and there is no socket close-by. I do have a start assistant in the trunk should the battery be drained.
I use my car almost every day so it should charge fairly well. My car is 6 years old now with the original battery as far as service history and documentation has shown. Been starting fairly well, but lets see how it does this swedish winter :happy:
I didn't, a trickle charger uses a low voltage to maintain a battery. They are actually smart chargers, you can leave them on for months and they'll fully charge the battery and discharge it to exceptable level several times all to extend the battery life.
Now for your type of batteries: There are 2 different types of stop-start batteries, EFB and AGM. The latter is the better type and lasts longer. A normal lead acid battery wouldn't last 2 years in a stop/start setup, regardless if it was fitted with a non smart alternator.
It's the constant restarting that would kill a normal lead acid battery off, a normal alternator wouldn't be able to actually give a faster charge as it doesn't have the circuitry to give a higher charge. And neither does the lead acid battery have any circuitry to be able to take a higher charge than 15v... it'll simply be damaged internally, and if left subject to that high charge long enough, ignite and burn everything around it.
But 5 years for an EFB battery is not bad, you can make it last longer if you use a trickle charger as i stated earlier. But the AGM batteries last longer as they use more advanced battery internals and circuitry.
Had my s3 since 2019 battery still ok but use a ctek charger at weekends to keep it topped up
Reactions: northpole
^This.
The smart charging/ ‘recuperation’ also dumps lots of charge into the battery on the over-run and EFB batteries struggle to handle this as well. That is in part why there is a need to specify the battery type in the BCM so the car knows not to push the battery too hard.
The early 8Vs came with AGM batteries from factory but this was later reverted to EFB+ probably to save money.
AGM batteries are also happy at partial states of charge whereas EFB+ need to be kept in sweet spot or they slowly dissolve their internals.
Forgot to add this to my post:
Standard alternator - charges the battery all the time, regardless of battery charge level, and whether needed or not, including on acceleration (marginally more fuel consumption and less performance). An antiquated concept these days.
Smart charging / recuperation: keeps battery charged to approximately 80% (not sure of the % but estimated guess). If battery low then charge all the time.
If battery charge ok then don’t charge on acceleration by dropping the voltage across the alternator to save a bit of fuel and marginally aid performance. In the cruise, charge as needed. However, on the over-run or when braking when no performance is needed and no fuel being used, dump loads of charge into the battery with negligible impact on speed at no fuel cost, and there is headroom in the battery to take this extra charge *and use it* - basically banking this extra electricity so charging can be paused when accelerating.
AGM batteries can happily cope with this, but EFB+ can’t: EFB+ are just a refinement of ~40 year old tech to limit the impact. As @northpole mentions, an AGM battery will outlive an EFB+ by a considerable margin, especially in this environment.
If replacing the battery, for the modest cost difference (+20-30 GBP) buy AGM but configure it in the car via VCDS or other tool as ‘fleece’ as the AGM label in the BCM means something else which is a separate rabbit hole.
Going back to your post title: standard charging will not be ‘reduced charging’ compared to smart charging / recuperation - smart charging is more efficient.
Reactions: Mikeso51 and northpole
Thank you all for sharing. I wasn't aware of the EFB/AGM difference. It's the original battery since 2019 as far as I know. Should I consider changing it? And if so, do I need to alter something in the coding through OBD-11 for it to recognize and AGM instead?
