A3 headlight washers !!! Not working
Xr2i
Wondering if anyone can give advice on this. I’ve my dipped headlights on and my headlight washers refuse to work even after multiple attempts, fuses 33 and 24 are fine. I’ve checked earth continuity on the brown at the pump which is fine, no issues with windscreen washer or wipers. I’ve tested the pump with a test probe and washers pop out no bother. I’ve also swapped the pump out for a genuine new one. Does relay 389 under the dash control this or only the wipers ? Can anyone tell me where the red/green positiveto pump plug goes back to as I’ve no 12v on it???
Ideally post this in your correct chassis section, but check if the relay that runs the washer pump works, if it's an 8P it's a separate pump to the windscreen washer.
Sorry it’s an 8L A3 windscreen washer pump working fine.
