Thanks for that - the pro version does seem more comprehensive.I think TMC-Pro provides a more comprehensive data set, however neither is a good as the real time traffic data provided via an internet connection
Thanks that could explain it.Possibly due to strength of carrier radio signal (TMC used to use Classic FM in the UK but not sure if that is still the case)
If you press and hold the volume knob until the screen goes blank and then shows the Audi logo, it forces a hard restart and that may restore TMC Pro for youI'm still occasionally struggling with this - it seems to be pot luck whether you get 'TMC' or 'TMC Pro' and the problem is that it seems to then be stuck for the whole day.
Most of the time it automatically connects to 'TMC Pro' and gets pretty accurate/up to date traffic info which is great but occasionally it gets stuck on 'TMC' only and the information is much more limited and vague (which is problematic on a long journey when you really need the traffic info).
I'm still not sure what determines whether the car connects to 'TMC' or 'TMC Pro' and if there is perhaps a way of manually overriding this or resetting the system if I really need it for a long journey. It would be great if anyone could shed any light on this?
Thanks for the suggestion (you seem to be the only person who replies on here) but I've already tried turning the MMI on/off and unfortunately it doesn't seem to reset the TMC connection.If you press and hold the volume knob until the screen goes blank and then shows the Audi logo, it forces a hard restart and that may restore TMC Pro for you
Probably means I have too much time on my hands!!Thanks for the suggestion (you seem to be the only person who replies on here) but I've already tried turning the MMI on/off and unfortunately it doesn't seem to reset the TMC connection.
