I'd had a very minor loss of coolant over the last year and a half - less than a litre and always seemed to lose most after topping up and then stabilised, never dropping below the minimum marker.
Decided to get it checked as I'd previously had a leak from the thermostatic valve housing which was replaced. Couldn't see any trace of a leak this time though.
Anyway, pressure test was fine but less than a week later I found PAG oil dripping from the car, probably 20ml so far on the garage floor and more lost out and about. Is this just an unlucky coincidence or is it possible the pressure test has caused it? i.e. applied pressure in the heater matrix that's triggered the leak. It seems to be coming from the condenser radiator although I've been unable to find the exact location.
