No power to stereo or cigarette lighter
kingbaldyiii
Windsor
Hope you can help
The cigarette lighter and stereo have no power going to them, they were working fine, I've checked the fuses by the driver door and all seem fine
Are there any other fuses I should be checking, or is there something really obvious I've missed ?
Thank you
Mike
I can't recall from my 8L days but check under bonnet for another box as I've found radio fuse was from there on some chassis's.
Reactions: kingbaldyiii
The cigarette lighter fuse of my 2003 S3 was in the side dash panel, driver's side, fuse #41
hth
Reactions: Sandra
hth
Thank you, I've checked and changed it still no power but thank you anyway
Fuse 41 15amp cigarette lighter, Fuse 5 7.5amp
E87 - Operating and display unit for Climatronic air conditioning system
E45 - Cruise control system switch
E94 - Heated driver seat regulator
E95 - Heated front passenger seat regulator
E159 - Fresh air and air recirculation flap switch
E221 - Operating unit in steering wheel
1)
F269 - Temperature flap position switch
G65 - High pressure sender
J293 - Radiator fan control unit
J401 - Navigation system with CD drive control unit
J402 - Navigation operating electronics control unit
J446 - Parking aid control unit
J453 - Multifunction steering wheel control unit
R - Radio
Y7 - Automatic anti-dazzle interior mirror
Under the bonnet, main fuse second from the left interior 110amp, apart from that I would check the grounding, then trace the wiring back to the fuse box at the end of the dash with a multimeter.
  • INTERIOR FUSE POSTIONS.pdf
  • RELAYS.pdf
  • FUSE BOX DIAGRAM.pdf
  • MAIN FUSE BOX.pdf
