Hi,
I’m having problems with my R8 going into limp mode. There’s a couple symptoms such as I can’t rev pass 4k, as it sounds like I’m bouncing off the limiter. Also I have had the EPC and the EML flash, but will disappear if I turn the car off and back on. I’ve run the VCDS and these are the error codes I have received :
008198 - Intake Manifold Flap; Bank 1
P2006 - 001 - Stuck Closed - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 104510 km
Time Indication: 0
Date: 2025.05.11
Time: 14:43:41
Freeze Frame:
RPM: 4013 /min
Load: 21.6 %
Speed: 76.0 km/h
Temperature: 103. ORC
Temperature: 37. ORC
Absolute Pres. : 1000.0 mbar
008199 - Intake Manifold Flap; Bank 2
P2007 - 001 - Stuck Closed - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 104510 km
Time Indication: 0
Date: 2025.05.11
Time: 14:43:41
Ln 1. Col 1
Freeze Frame:
RPM: 4010 min
Load: 21.6 %
Speed: 76.0 km/h
Temperature: 103.00C
Temperature: 37.08C
Absolute Pres.: 1000.0 mbar
Voltage: 13.843 V
*Is this a sensor that needs replacing or something greater? I feel like I got a my first sign a couple months ago when I was driving and the car for a split second seemed like it was suffocating and hit a wall… this has only happened only a handful of times. Then I experienced the EPC light about 3 weeks ago for the first time, A quick off and on and it disappeared, Then the car would be fine had been fine for a couple weeks. I drive it every weekend, but the weekend just gone it has happened again and now I can’t get it to go away….
Where do I start?
Regards
Harve
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 104510 km
Time Indication: 0
Date: 2025.05.11
Time: 14:43:41
Freeze Frame:
RPM: 4013 /min
Load: 21.6 %
Speed: 76.0 km/h
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Reset counter: 255
Mileage: 104510 km
Time Indication: 0
Date: 2025.05.11
Time: 14:43:41
Ln 1. Col 1
Freeze Frame:
RPM: 4010 min
Load: 21.6 %
Speed: 76.0 km/h
Temperature: 37.08C
Voltage: 13.843 V
Where do I start?
Regards
Harve
